#716: projectsVM: awstats not running
Reporter: neteler | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
The awstats installation on the projectsVM is incomplete. I tried for a
while to fix it but apparently I am missing something.
I put the previous config file for GRASS in
/etc/awstats/
Perhaps there were more projects which had been hosted on the crashed
xblade14 telascience machine but their config files got lost.
A fix + reprocessing of the logs would be great. Thanks.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/716>
OSGeo <http://www.osgeo.org/>
Comment(by wildintellect):
We actually have copies of the old logs on backup. Now that I've taken
care of Downloads awstats I can take a shot at the projectsVM. If other
projects want theirs reinstated please let me know.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/716#comment:1>
Comment(by neteler):
The GRASS logs go back to 2002, please let me know if your backup is less.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/716#comment:2>
I've attached a list of the awstats backup we have, it goes back to 2002
but does not cover all months in 2002.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/716#comment:3>
Looks good to me.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/716#comment:4>
Comment(by hamish):
slightly offtopic but I notice there's a perl process on the projects VM
which has been running at 100% cpu since 29 March (openlayers). Expected
or when good cron jobs go bad?
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/716#comment:5>
I've moved all of the old awstats into place from Markus' home folder on
Projects.
Now I'm running a script (attachment:awststats-historical.sh) to rerun all
the logs that haven't been run yet. Might take a day to catch up.
Using ./awstatshistoric.sh grass.osgeo.org grass.osgeo.org-access_log 10
It takes 3 args and should be universal enough to handle processing other
projects old awstats.
Once this is done running I will add the cron job to do at least a daily
run of awstats (depending on the amount of traffic I might make it 2-3
times a day), all of which is nice -19.
Awstats can be viewed for the grass project @
http://grass.osgeo.org/stats/
The end / is necessary, strk and I haven't found a way around that yet.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/716#comment:6>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by wildintellect):
* status: new => closed
* resolution: => fixed
Comment:
GRASS is now 100% up to date and awstats is being run via cron 2x a day
with nice to keep it from affecting services. If any other projects want
awstats please open/reopen a ticket to let me know.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/716#comment:7>
