#723: QGIS Trac -> Redmine migration
Reporter: timlinux | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: trac qgis backup
Hi
For various reasons, we have decided to migrate our ticket tracker to
redmine (http://www.redmine.org/). In order to do the migration, I will
need to have a current backup of our trac project (the redmine migration
tools need to work on a local copy of trac). Obviously we will also need a
dump of the database (or the sqlite .db as appropriate).
Could you please make these available to me at your earliest convenience?
I will make our current trac instance read only from that point (and re-
activate it again if we encounter any issue with the migration).
Many thanks
Tim
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/723>
OSGeo <http://www.osgeo.org/>
Comment(by wildintellect):
qgis-dump.zip can now be found in my home dir on the QGIS VM. Thanks to
Chris for doing a trac hotcopy and a pg_dump
Please update ticket if it works or fails.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/723#comment:1>
Comment(by timlinux):
Just an update - I am still busy getting the migration to work - I will
probably ask for a fresher dump at the point that I have a repeatable
procedure so please keep this ticket open for now.
Thanks
Tim
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/723#comment:2>
Hi
I have done a successful migration on my desktop to test. I'd like to run
it on the server with a current dump. Would you please provide an up to
date dump for me so I can run the final migration? I need both db dump and
trac dir tarball.
Thanks very much.
Regards
Tim
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/723#comment:3>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: trac qgis backup |
Changes (by wildintellect):
* status: new => closed
* resolution: => fixed
Comment:
This task is done, results can be seen at http://hub.qgis.org
Good example case for additional Redmine/Git migrations in the future.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/723#comment:4>
