#724: time on lists.osgeo.org in future
Reporter: neteler | Owner: sac@…
Type: task | Status: new
Priority: critical | Milestone:
Component: Systems Admin | Keywords:
I got notified that the time is in future on the list server.
Current real time:
date -u
Thu May 19 10:48:19 UTC 2011
lists.osgeo.org:
root@peer1_1:neteler # date -u
Fri May 20 07:42:26 UTC 2011
I have restarted ntpd but I am not sure that this helps.
On Thu, May 19, 2011 at 01:13:43PM -0000, OSGeo wrote:
I have moved it forward three hours to be within a minute or two of
correct. I'm not sure why it is/was out of whack.
root@peer1_1:~ # date -u
Fri May 20 13:52:58 UTC 2011
root@peer1_1:~ # ntp
root@peer1_1:~ # /etc/init.d/ntpd stop
Shutting down ntpd: [ OK ]
root@peer1_1:~ # ntpdate time.peer1.com
19 May 09:52:03 ntpdate[6291]: step time server 66.132.181.236 offset -86473.375311 sec
Thu May 19 13:52:06 UTC 2011
root@peer1_1:~ # /etc/init.d/ntpd start
Starting ntpd: [ OK ]
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
On Thu, May 19, 2011 at 06:52:16PM +0200, Markus Neteler wrote:
For the record: I tried the same but did "restart" of the daemon
which didn't have any effect. Stop/starts seems to be better,
Yup. BTW, the kernel-PLL appears to be totally out of tune. I've
already tried to apply a few countermeasures (regarding the NTP drift
file and '/etc/adjtime'), but it might take a few days until it's back
into reasonable shape.
Martin.
please double check `ntpq -p` as well after a while and ensure it
is talking to the time servers you think it is.
(at least Ubuntu 10.04 LTS pushed in a ntp change in the last
versions that silently ignores servers in ntp.conf if the DHCP
host has supplied (or begins to supply) some.. argh!)
# ~> while true; do ntpdc -p; sleep 3; done
In general I'd welcome if distributions honour the DHCP "ntp-servers"
option, as far as I can tell, very, very few are doing this, if any.
The state on 'osgeo1' is steadily getting better, still not synced to
any of the NTP servers, but the growth of the offset has slowed down
significantly.
Martin.
