#727: make awstats page available at the /stats/ alias
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
See http://lists.osgeo.org/pipermail/sac/2011-May/003125.html
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/727>
OSGeo <http://www.osgeo.org/>
Comment(by tmitchell):
This would be a welcome improvement on osgeo1/www.osgeo.org too ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/727#comment:1>
Comment(by wildintellect):
We got so far as to get it to be /stats/
All it takes is the awstats config has to be named for the domain and one
apache line.
so awstats.www.osgeo.org.conf
and
ScriptAlias /stats /usr/lib/cgi-bin/awstats.pl
See GRASS on projects vm for a working example.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/727#comment:2>
Comment(by strk):
I'd think that's good enough for the time being. Can always be improved in
a second step by redirecting /stats to /stats/
Note, the wiki should also be updated about stats:
http://wiki.osgeo.org/wiki/Download_Server#Access_Log_Viewer_.28awstats.29
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/727#comment:3>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by wildintellect):
* status: new => closed
* resolution: => fixed
Comment:
1. Alias Added, use http://download.osgeo.org/stats/
1. Removed www from config name
1. Modified cron to hit the right config
1. Renamed all the awstats history files to remove www
for i in *www.download*; do mv "$i" "${i/\.www/}"; done
Old URL won't work anymore it's now http://download.osgeo.org/cgi-
bin/awstats.pl?config=download.osgeo.org if you want to use the full one
(in case you want to pull up another servers stats)
Wiki has been updated.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/727#comment:4>
