#738: LDAP logins to Projects VM failing
Reporter: warmerdam | Owner: sac@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Systems Admin | Keywords: ProjectsVM LDAP
It seems that LDAP logins to the project VM have stopped working. I
believe this was first observed on July 12th or so (jmckenna) and I have
confirmed this (warmerdam). Martin is apparently looking into the problem
without it being immediately obvious what is wrong.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738>
OSGeo <http://www.osgeo.org/>
Changes (by dmorissette):
* cc: dmorissette (added)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738#comment:1>
Priority: critical | Milestone:
Changes (by martin):
* priority: major => critical
Comment:
It's working again, but I wonder why the person behind the user account
'crschmidt' has installed a custom SSH server binary last Saturday ....
If Chris Schmidt himself didn't, then we should consider the 'projects' VM
as being compromised and _everyone_ who has tried password authentication
on the 'projects' VM, I repeat: _everyone_ is urged to change his LDAP
password.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738#comment:2>
Comment(by crschmidt):
No, I did not do this. Presumably my account was compromised in some way.
(My password is relatively strong, and I only use it for OSGeo-related
activities, so I'm not sure how my account was compromised; I'd apologize,
but at this point it doesn't seem like it would do much good.)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738#comment:3>
Comment(by martin):
Ok, all binaries in /bin/, /sbin/, /usr/bin/, /usr/sbin/ as well as all
libraries which are linked from SSH binaries do _not_ look suspicious.
With a little bit of luck we're done by everybody in the "telascience"
shell group changing their LDAP passwords if they tried to log into the
'projects' VM recently (since Saturday). Everybody !!
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738#comment:4>
Comment(by tmitchell):
Does this affect shared key authorization for crschmidt under root
accounts on other VMs? Just wondering if we should pull any of those
keys, if they exist.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738#comment:5>
No, that key is only on my laptop, and from what I can tell, the machine
which was compromised was my webserver. So I don't think that we need to
worry about anyone having access to the private key for one of the root
accounts.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738#comment:6>
Okay, that makes sense. I was thinking more that if the shared key on the
servers was changed (or anyone other keys changed), it would give another
easy way to log in without needing your private one.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738#comment:7>
Martin checked out a number of things on that server (including the root
authorized_keys) and found no other modifications / additions; it looks
like we have a full log of the things that were done to the system, and it
was just changing the SSH daemon to the manually copied in one. I think
the most important part now is just to get everyone with shell access who
has logged in since Saturday to change their passwords, so I'll send out
an email tonight to everyone in the shell group with this information.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738#comment:8>
Type: defect | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: ProjectsVM LDAP |
Changes (by wildintellect):
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/738#comment:9>
