#78: Subversion does not allow commit of .jsp file extensions
Reporter: trevorwekel | Owner: sac@lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: SAC
Keywords: JSP commit mapguide |
Subversion does not allow to me commit a file with a ".jsp" extension to
the mapguide vault.
Sending mapviewerjava\mapframe.jsp
Transmitting file data .svn: Commit failed (details follow):
svn: PUT of '/mapguide/!svn/wrk/72ac8ff1-e849-7448-845e-
713e137ecd01/trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp': Could not
read status line: An existing connection was forcibly closed by the remote
host. (http://svn.osgeo.org)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/78>
OSGeo <http://www.osgeo.org/>
Resolution: | Keywords: JSP commit mapguide
Comment (by warmerdam):
Trevor,
Is this repeatable? Can you confirm that non-jsp files are not a problem?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/78#comment:1>
Resolution: | Keywords: JSP commit mapguide subversion
Changes (by warmerdam):
* keywords: JSP commit mapguide => JSP commit mapguide subversion
Comment:
I just got the following on the GDAL repository, but it was because I
didn't
respond to the interactive prompt quickly enough so apparently the
connection
timed out.
(R)eject, accept (t)emporarily or accept (p)ermanently? t
svn: PROPFIND request failed on '/svn/gdal/trunk/gdal'
svn: PROPFIND of '/svn/gdal/trunk/gdal': Could not read status line:
connection was closed by server. (https://svn.osgeo.org)
So, i'm wondering if the issue might just be a timeout issue.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/78#comment:2>
Comment (by waltweltonlair):
I had the exact same problem with jsp files (and unfortunately entered a
separate ticket - #79 - since I didn't see this one).
Frank suggests this may be a timeout issue. If I try committing just one
file I get the error about 5 seconds after submitting the commit command.
Seems a bit fast for a timeout, but what do I know.
The interesting thing is that I was able to successfully commit my changes
to jsp files from a Linux machine. Only on Windows did I have the
problem. Both machines have the subversion 1.4.3 client installed.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/78#comment:3>
Comment (by trevorwekel):
The jsp file I was trying to commit was contained as part of a larger
submission. When I removed the jsp from the list, all of the other files
went through ok. I was commiting from Windows and neither Tortoise or
Subversion would let me commit the file. Even commiting just the single
jsp file bailed out after 5-10 seconds.
I will try Walt's suggestion of commiting from Linux instead of Windows.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/78#comment:4>
Comment (by anonymous):
I found the problem! I happened to notice a bunch of these messages in my
Proventia Desktop log:
[Denial of Service] This signature detects an HTTP URL request that
contains QUOT;jsp?" followed by more than 2000 characters.
Here at Autodesk Proventia is installed by our IT group on all our Windows
machines.
That also explains why it wokred for me on Linux.
I think we can call tickets 78 and 79 fixed. We will take this up with
our IT group...
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/78#comment:5>
Type: defect | Status: closed
Resolution: worksforme | Keywords: JSP commit mapguide subversion
* status: new => closed
* resolution: => worksforme
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/78#comment:6>
