#79: possible SVN corruption in MapGuide vault?
Reporter: waltweltonlair | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: major | Component: SAC
Keywords: |
When I try to commit any change to the
http://svn.osgeo.org/mapguide/trunk/MgDev/Web/src/mapviewerjava
directory I get errors like the following:
Sending product.jsp
Transmitting file data .svn: Commit failed (details follow):
svn: PUT of '/mapguide/!svn/wrk/f7df244e-09a7-7545-b620-
314ad3e076c1/trunk/MgDev/Web/src/mapviewerjava/product.jsp': Could not
read status line: An existing connection was forcibly closed by the remote
host. (http://svn.osgeo.org)
Is everything ok with the repository?
Walt
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/79>
OSGeo <http://www.osgeo.org/>
Resolution: | Keywords:
Comment (by warmerdam):
See also, ticket #78 which may be related.
I'm suspecting that the "Could not read status line: An existing
by the remote host." message is due to a connection timeout.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/79#comment:1>
Type: task | Status: closed
Resolution: fixed | Keywords:
Changes (by warmerdam):
* status: new => closed
* resolution: => fixed
Comment:
trevorwekel reports:
I found the problem! I happened to notice a bunch of these messages in
my
Proventia Desktop log:
[Denial of Service] This signature detects an HTTP URL request that
contains QUOT;jsp?" followed by more than 2000 characters.
Here at Autodesk Proventia is installed by our IT group on all our
Windows
machines.
That also explains why it wokred for me on Linux.
I think we can call tickets 78 and 79 fixed. We will take this up with
our IT group...
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/79#comment:2>
Type: task | Status: reopened
Changes (by waltweltonlair):
* status: closed => reopened
* resolution: fixed =>
Comment:
''I just heard back from Autodesk IT, and according to them the correct
method to resolve this issue would be to apply the required patch to the
web server. See the following info...''
[[BR]]
!WebLogic redirect request plug-in buffer overflow can be used to gain
root (HTTP_WebLogic_PluginBO)
'''Vulnerability description'''
BEA !WebLogic Server and !WebLogic Express versions 5.1.0 and 4.5.x are
vulnerable to a buffer overflow in the plugin that allows other Web
servers to redirect requests to the !WebLogic server. By requesting a Java
Server Page (.JSP file) from the BEA !WebLogic server with a URL
containing 2048 characters or more, a remote attacker can overflow a
buffer and crash the Web server or execute arbitrary code on the system.
An attacker may be able to use this to gain root level privileges in Unix
or SYSTEM privileges in Windows NT.
'''How to remove this vulnerability'''
Apply the proxy plug-in patch, as listed in BEA Systems, Inc. Security
Advisory BEA00-05.01. See References.
'''References'''
'''BEA Systems, Inc. Security Advisory BEA00-05.01'''
[[BR]]Patch Available for Buffer Overflow in BEA !WebLogic Server Proxy
Plug-In
[[BR]]http://dev2dev.bea.com/pub/advisory/40
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/79#comment:3>
Resolution: invalid | Keywords:
Changes (by jbirch):
* status: reopened => closed
* resolution: => invalid
Comment:
Walt,
The problem is that your security system is getting tripped because the
SVN commit signature looks the same as the security issue that is
indicated in that alert.
There's nothing that can be done on the OSGeo server to prevent your IPS
from seeing an SVN commit of a JSP file followed by N bytes as this
vulnerability.
At this point I think your options are to get your IT department to drop
the rule, to create a special policy just for your workstation (if this is
possible with your software), or to continue using Linux to commit JSP
files.
I had the same thing happen to me with our CheckPoint SPI firewall last
year. It wouldn't allow me to view MapBender maps because they contained
too many characters in an image tag (the WMS string). Eventually, my tech
support guys made a special rule for me, and then once they were happy
that all of the workstations had been patched against that particular
vulnerability they turned it off altogether.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/79#comment:4>
