#811: Failed to Transfer file Method Not Allowed
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
I just failed when following my GeoTools release procedure (sigh!).
The failure was returned as:
Failed to transfer file:
http://download.osgeo.org/webdav/geotools/org/geotools/geotools/8.0-M2/geotools-8.0-M2.pom.
Return code is: 405 Method Not Allowed -> [Help 1]
Any suggestions? It appears as if my credentials are in order.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/811>
OSGeo <http://www.osgeo.org/>
Comment(by jive):
Version of maven used:
Apache Maven 3.0.3 (r1075438; 2011-03-01 03:31:09+1000)
Maven home: /usr/local/Cellar/maven/3.0.3/libexec
Java version: 1.6.0_26, vendor: Apple Inc.
Java home:
/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home
Default locale: en_US, platform encoding: MacRoman
OS name: "mac os x", version: "10.7.1", arch: "x86_64", family: "mac"
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/811#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: duplicate
Keywords: download |
Changes (by warmerdam):
* keywords: => download
* status: new => closed
* resolution: => duplicate
Comment:
I believe the issue is that webdav has not been setup yet on the new
server as discussed in #798.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/811#comment:2>
Comment(by wildintellect):
Basically this is a repeat of Ticket #607 since we don't seem to have a
backup of the webdav config from the previous download server. So we'll
need to follow the same steps to get it up and running and then make sure
to include it in the backup this time.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/811#comment:3>
