If you then click on the link to the 3.8 downloads page it won't be found
whether you have connected via https or http. You have to manually enter
the https protocol for that link to get the page to appear.
Is this just me or is there a problem with the site?
regards
Neil
On Mon, Jan 13, 2014 at 9:28 AM, Neil Penman <neilpenman@gmail.com> wrote:
Can someone please take on this FDO downloads issue? Or put up a notice
there that it is a known issue? I think 3 messages came in today alone
to info@osgeo regarding this (example pasted below). Thanks.
-jeff
Just an FYI, none of the downloads pages work on the Osgeo FDO website?
For example,
regards
Neil
I'll try, but, to be honest, I don't have the slightest idea about what
to expect on these FDO pages .... To me it looks like they're being
handled by Drupal,
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Can anyone confirm this is a rather new issue ? I'm asking because:
a) "fdo.osgeo.org/content/downloads" refers to
"/var/www/fdo/content/downloads" in the local filesystem.
b) "/var/www/fdo/content" is a symlink to "/var/www/drupal/content" -
the symlink was established in 2007.
c) The "/var/www/drupal/content" directory has been unchanged since
2006 - and there is no subdirectory named "downloads".
It looks like I fixed some other broken links to
"http://fdo.osgeo.org/files/...." by replacing the directory
"/var/www/fdo/files" by a symlink to "/var/www/drupal/files" - like
other sites do.
Unfortunately the netwok connection just broke, I'll try to check
later, maybe this weekend.
Martin.
Martin.
Martin.
root@peer1_1:conf.d # ifconfig
bash: ifconfig: command not found
root@peer1_1:conf.d # /sbin/ifc
ifcfg ifconfig
root@peer1_1:conf.d # /sbin/ifconfig
eth0 Link encap:Ethernet HWaddr 00:30:48:59:8A:C0
inet addr:66.223.95.242 Bcast:66.223.95.255 Mask:255.255.255.240
eth0:0 Link encap:Ethernet HWaddr 00:30:48:59:8A:C0
inet addr:66.223.95.245 Bcast:66.223.95.255
Mask:255.255.255.240 <<<----
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
Interrupt:185
In /etc/httpd/conf.d/rewrite.conf I see a commented rule:
# FDO has a real subdomain #RewriteCond %{HTTP_HOST} ^fdo\.osgeo\.org$ #RewriteRule ^/(.*) http://osgeo.org/fdo [R,L]
ifcfg ifconfig
Interrupt:185
My micro-contribution,
Now solved and I get what's going on-ish. Apache was being sent to the
wrong root of Drupal for http, but a different place for https.
The rewrite rule appear to be from some older config and not related.
Can someone please let the fdo project know it's fixed and ask them to
please update the FOSS4G Ad to 2014.
ifcfg ifconfig
Interrupt:185
I just took a look, and while slow the website is running.
As for where those files are, looks like we didn't know about them in
the migration we did a month ago. Since they appear to be static.
Url says /files, closest thing I can find is /var/www/osgeo/files/fdo
which points to /var/www/webdav which doesn't exist. Appears to be the
same for mapguide. I don't know the direct ip for osgeo1 or if peer1
turned it off already as we requested.
It does not appear to be /var/www/drupal-5.23/sites/fdo.osgeo.org/files/
which is a drupal folder, but I could be wrong and have no idea if that
folder is supposed to have files or not.
I think someone from the fdo and mapguide communities needs to step up
and give us an idea of what's going on, and if they have another copy of
the files in question that can be uploaded.
ifcfg ifconfig
Interrupt:185
Checking this thread it looks like the last point of action was to get
Jackie admin access. After which Jackie would clean up the links.
I'm not sure that ever happened. Perhaps Christian or Martin could check
that user:jng
is an admin on those drupal sites (I can't even log into them).
Though I'm not sure those sites are using OSGeo Ids, maybe that is the
issue? Side note, if is using osgeo ids we need to push the login page
to https.
As for the no response on the fdo trac, that's fdo project members
responsibility. Since it sounds like SAC help is needed, forwarding or
filing with SAC makes sense.
Alex
On 01/08/2015 06:11 AM, Jeff McKenna wrote:
A user filed a ticket a few months ago about none of the doc and
download links working[1], but hasn't got any response yet.
Regarding no response: yup, in fact I said the same thing in that ticket. Right now it's more of an issue of getting the work done/fixing this, than proper channels (I think we are both preaching to the choir).
-jeff
that user:jng
to https.
Alex
