OSGeo Admins,
I’d like to do several changes to your Ganeti cluster eventually to bring it up to a better supported platform and version of Ganeti as well. Unfortunately this is going to cause some downtime for each node but I’m pretty sure I can do it without losing data or downtime to certain VMs. Both of your nodes are currently running Gentoo which we haven’t been maintaining other than for very important security issues that come up. Also, the version of Ganeti is currently 2.6.2 and the latest stable version is 2.15.2 which includes several improvements.
The summary of items I’d like to do are:
Install CentOS 7 as the OS for all of the nodes
Switch to managing said nodes to Chef instead of Cfengine
Upgrade Ganeti from 2.6.2 to 2.15.2 (or whatever is stable at the point we get to this)
This is going to need to be a multi-stage process unfortunately, but I’m hoping I only have to do one down time per node. I’ve tested this process in a Vagrant environment and it seems to work.
Here’s the actual steps I plan to do:
Take osgeo3 down and reinstall it’s OS with CentOS 7 and retain it’s LVM data for VMs
Install Ganeti 2.6.2 on osgeo3 using Chef so that the version stays the same throughout the whole cluster
Readd osgeo3 back into the cluster using its previous configuration and start all the VMs back up
Repeat the process of steps 1 through 3 with osgeo4
Upgrade Ganeti to 2.11.8 on all the nodes (I’ve found this to be safer than jumping from 2.6.2 directly to 2.15 as they made some major changes to the backend in those versions)
Finally upgrade Ganeti to 2.15.2 or whatever is latest stable at the time.
So my questions to you are:
- Should any of the instances below be migrated to another node during it’s primary node downtime? If so and they’re currently set to plain, we can convert them to DRBD, it will just take a short downtime (depending on how large the disk is) and move them over.
- When could we start doing this? I was hoping to start within the next month or so but it can certainly be adjusted.
- How should we communicate in real-time if we need to? Via #osuosl on IRC? Other means?
Instance | Primary_node | Status | Memory | DiskUsage | Disk_template |
adhoc.osgeo.osuosl.org | osgeo4.osuosl.bak | running | 4096 | 65536 | plain |
base.osgeo.osuosl.org | osgeo3.osuosl.bak | ADMIN_down | - | 4096 | plain |
download.osgeo.osuosl.org | osgeo3.osuosl.bak | running | 8192 | 158720 | plain |
mail.osgeo.osuosl.org | osgeo4.osuosl.bak | running | 4096 | 75776 | plain |
projects.osgeo.osuosl.org | osgeo4.osuosl.bak | running | 16384 | 208896 | plain |
qgis.osgeo.osuosl.org | osgeo4.osuosl.bak | running | 6144 | 167936 | plain |
secure.osgeo.osuosl.org | osgeo3.osuosl.bak | running | 4096 | 14464 | drbd |
tracsvn2.osgeo.osuosl.org | osgeo3.osuosl.bak | ADMIN_down | - | 86016 | plain |
tracsvn.osgeo.osuosl.org | osgeo3.osuosl.bak | running | 8192 | 106496 | plain |
web.osgeo.osuosl.org | osgeo3.osuosl.bak | running | 4096 | 36864 | plain |
webextra.osgeo.osuosl.org | osgeo3.osuosl.bak | running | 4096 | 126976 | plain |
wiki.osgeo.osuosl.org | osgeo3.osuosl.bak | running | 4096 | 20480 | plain |
Thanks-
Lance Albertson
Director
Oregon State University | Open Source Lab
