I got a warning that the certificate had expired just now, but I am travelling so it may be a false positive. Can we check please?
Jody Garnett
Jody Garnett
The certificate expired today. The cron to update the cert must not be running or the process is failing.
Michael Smith
Jody Garnett
Sac mailing list
Sac@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/sac
Michael Smith
Jody Garnett
There was a warning email from lets encrypt (I got on my personal accounts). If using certbot it need to be updated so that a new method of renenwal is used.
Sandro or Regina, did you set this one up?
Alex
Ok, I've fixed it. I think apache was failing to load the renewed certificate, 2 possible reasons:
1. certbot was really old version, now upgraded via apt-get, did a dry run of the renew which didn't find any expired certs.
2. apache had a staging.2018.foss4g.org-le-ssl.conf enabled, but not matching certificate. I removed it from sites enabled and reloaded apache. We can re-enable if we need.
So fixed, and should stay fixed.
Alex
Michael Smith
Jody GarnettThere was a warning email from lets encrypt (I got on my personal accounts). If using certbot it need to be updated so that a new method of renenwal is used.
Alex
Sac mailing list
Sac@lists.osgeo.org
Thank you everyone
Jody Garnett
Sorry all. Guess late to the party on this.
Yes I did setup the staging.2018.foss4g.org I thought I had shut that down and revoked it a while ago though.
Yes I did get notices about letsencrypt old certbot will no longer be supported.
I only got a notice about the limesurvey.osgeo.org one though which is on funtoo which I’ll check on before it expires. That one is due to expire in March 1,2019.
Sent: Sunday, January 27, 2019 10:36 PM
To: Alex Mandel tech@wildintellect.com; System Administration Committee Discussion/OSGeo sac@lists.osgeo.org
Cc: Michael Smith michael.smith.erdc@gmail.com; Regina Obe lr@pcorp.us; Sandro Santilli strk@osgeo.org
Subject: Re: [SAC] osgeo.org certificate?
Thank you everyone
Jody Garnett
On Sun, 27 Jan 2019 at 20:19, Alex Mandel <tech_dev@wildintellect.com> wrote:
Ok, I’ve fixed it. I think apache was failing to load the renewed
- certbot was really old version, now upgraded via apt-get, did a dry
run of the renew which didn’t find any expired certs.- apache had a staging.2018.foss4g.org-le-ssl.conf enabled, but not
apache. We can re-enable if we need.So fixed, and should stay fixed.
running or the process is failing.Michael Smith
wrote:I got a warning that the certificate had expired just now, but I am
travelling so it may be a false positive. Can we check please?–
of renenwal is used.Sandro or Regina, did you set this one up?
Alex
Sac mailing list
Sac@lists.osgeo.org
Sac mailing list
Sac@lists.osgeo.org
