FYI
Time to switch to let’s encrypt with certbot?
---------- Forwarded message ----------
From: “Moritz Lennert” <mlennert@club.worldonline.be>
Date: Jan 29, 2017 3:49 PM
Subject: Re: [GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1898 (master - 7fa0125)
To: <grass-dev@lists.osgeo.org>
Cc: <landa.martin@gmail.com>
There seems to be an issue with Travis which cannot download trunk:
==> Cloning https://svn.osgeo.org/grass/grass/trunk
Error validating server certificate for ‘https://svn.osgeo.org:443’:
- The certificate is not issued by a trusted authority. Use the
fingerprint to validate the certificate manually!
Certificate information:
Hostname: *.osgeo.org
Valid: from Thu, 28 Apr 2016 00:00:00 GMT until Wed, 01 May 2019
23:59:59 GMTIssuer: www.ssl.com, SSL.com, US
Fingerprint:
56:50:0d:63:0f:47:10:92:7a:3a:b5:a9:83:f8:97:92:fe:d6:19:95(R)eject, accept (t)emporarily or accept (p)ermanently? svn: E175002:
Unable to connect to a repository at URL
‘https://svn.osgeo.org/grass/grass/trunk’svn: E175002: OPTIONS of ‘https://svn.osgeo.org/grass/grass/trunk’:
Server certificate verification failed: issuer is not trusted
(https://svn.osgeo.org)Error: Failed to download resource “grass-trunk”
Moritz
Le Sun, 29 Jan 2017 14:15:13 +0000,
Travis CI <builds@travis-ci.org> a écrit :Build Update for GRASS-GIS/grass-ci
Build: #1898
Status: Still FailingDuration: 5 minutes and 46 seconds
Commit: 7fa0125 (master)
Author: Moritz Lennert
Message: v.to.db: added bounding box as additional measure (onesuggestion of #2122)
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70451
15284696-431f-4ddb-bdfa-cd5b030d7da7View the changeset:
https://github.com/GRASS-GIS/grass-ci/compare/e3953483e94b…7fa01253b0a8View the full build log and details:
https://travis-ci.org/GRASS-GIS/grass-ci/builds/196338327–
You can configure recipients for build notifications in
your .travis.yml file. See
https://docs.travis-ci.com/user/notifications
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
