on it . . .
bobb
On Jul 15, 2019, at 1:18 PM, OSGeoLive <trac_osgeolive@osgeo.org> wrote:
Think Before You Click: This email originated outside our organization.
#2154: GeoMoose website is down
Reporter: kalxas | Owner: osgeolive@…
Type: defect | Status: new
Priority: critical | Milestone: OSGeoLive13.0
Component: OSGeoLive | Keywords:
https://www.geomoose.org is down{{{
Starting "install_geomoose.sh" ...
--2019-07-15 13:30:22--
https://www.geomoose.org/downloads/gm3-examples-3.3.1.zip
Resolving www.geomoose.org (www.geomoose.org)... 52.15.94.38
Connecting to www.geomoose.org (www.geomoose.org)|52.15.94.38|:443...
failed: Connection timed out.
Retrying.--2019-07-15 13:32:33-- (try: 2)
Retrying.--2019-07-15 13:34:45-- (try: 3)
Giving up.--2019-07-15 13:36:56-- https://www.geomoose.org/downloads/gm3-demo-
data-3.3.1.zip
Retrying.--2019-07-15 13:39:08-- (try: 2) https://www.geomoose.org/downloads/gm3
-demo-data-3.3.1.zip
Retrying.--2019-07-15 13:41:21-- (try: 3) https://www.geomoose.org/downloads/gm3
Giving up.unzip: cannot find or open gm3-examples-3.3.1.zip,
gm3-examples-3.3.1.zip.zip or gm3-examples-3.3.1.zip.ZIP.
unzip: cannot find or open gm3-demo-data-3.3.1.zip, gm3-demo-
data-3.3.1.zip.zip or gm3-demo-data-3.3.1.zip.ZIP.
mv: cannot stat '/tmp/build-geomoose/gm3-examples': No such file or
directory
mv: cannot stat '/tmp/build-geomoose/gm3-demo-data': No such file or
directory
./install_geomoose.sh: 60: ./install_geomoose.sh: cannot create
/usr/local/geomoose/gm3-examples/htdocs/desktop/config.js: Directory
nonexistent
./install_geomoose.sh: 67: ./install_geomoose.sh: cannot create
/usr/local/geomoose/gm3-examples/htdocs/mobile/config.js: Directory
nonexistent
./install_geomoose.sh: 74: ./install_geomoose.sh: cannot create
/usr/local/geomoose/gm3-demo-data/temp_directory.map: Directory
nonexistentFinished "install_geomoose.sh"
Disk Usage1: install_geomoose.sh,Filesystem,1K-
blocks,Used,Available,Use%,Mounted_on,date
Disk Usage2: install_geomoose.sh,-,38183,20238,15977,56%,/,2019-07-15
13:43:32+00:00
Temp Usage: install_geomoose.sh,1369 /tmp}}}
Ticket URL: <https://trac.osgeo.org/osgeolive/ticket/2154>
OSGeoLive <http://live.osgeo.org/>
self-contained bootable DVD, USB thumb drive or Virtual Machine based on Lubuntu, that allows you to try a wide variety of open source geospatial software without installing anything.
osgeolive mailing list
osgeolive@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/osgeolive
