Could you please disable the rebuild-on-commit logic for telascience-quick?
I believe this is resulting in too much activity on the server.
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
On Nov 12, 2008, at 10:06 AM, Frank Warmerdam wrote:
Mateusz,
I have disabled the build-on-commit notifications for both GDAL and MapServer. To re-enable, the line in each repository's post-commit script must be uncommented.
I took out the telascience-quick by commenting out the addBuilder command in a_telascience.py. There is also a common configuration object in _common.py, which now (since Nov 3?) has config['quick'] = False. These are both in /osgeo/buildbot/gdal/buildmaster/config
I already sorted out once how the scheduling is done, but forgot it The configuration is a bit hairy since the pieces are spread into several files. I'd like to have my gdal-msys build happen only in our night but it's not easy since the scehduler is shared between slaves.
I'm not sure if the current schedulers are just twice a day or is the scheduler, which starts a build after a certain time after commits, is in effect.
Ari
Prof. Ari Jolma
Environmental Management Information Technology
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 4511 address: POBox 5300, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://geoinformatics.tkk.fi
Frank,
For all buildbot instances or for GDAL only?
I see Hobu has already fixed it, am I correct?
Mateusz,
I only meant for GDAL though I'm not clear what other instances might being
doing it too. I believe it is now taken care of. I'm trying to diagnose
why xblade14 still seems saturated much of the time.
Best regards,
Ari,
To disable build on commit we only need to comment these lines
in master.cfg file of a buildbot instance:
Thanks, I was looking for master.cfg but did not find it since it does not have .py extension although it is python. Too much work and no play I guess.
Prof. Ari Jolma
I guess it disables quick builders completely.
Sorry, I have too weak net link to search through buildbot documentation and mailing lists about this option.
Anyway, what I'm sure is that disabling change source does the job.
