I am looking for the point of contact in SAC for the OAuth App access - settings on GitHub. Please advise.
Reason:
Last week it was learned that the GitHub-Zenodo integration for the projects GDAL and PROJ has ceased to work, without the project communities having taken any actions.
Both projects had successfully set up GitHub-Zenodo integrations earlier in 2022 to allow automated archiving of new software releases in the Open Access repository Zenodo (zenodo.org).
This is the response from the Zenodo service desk:
"Although you appear to have the correct authorization credentials, the `OSGeo` organization has enabled OAuth App access restrictions, meaning that data access to third-parties is limited. For more information on these restrictions, including how to enable this app, visit https://docs.github.com/articles/restricting-access-to-your-organization-s-data/"\.
The issue with the GitHub-Zenodo integration appeared somewhere after July 2022. Previously this worked for GDAL, PROJ and GRASS and then stopped afterwards.
Reason:
“Although you appear to have the correct authorization credentials, the OSGeo organization has enabled OAuth App access restrictions, meaning that data access to third-parties is limited. For more information on these restrictions, including how to enable this app, visit https://docs.github.com/articles/restricting-access-to-your-organization-s-data/”.
