Hello,
I'm still trying to get PostgreSQL running on the Telascience server (http://mapbender.telascience.org/). But I don't seem to get anywhere, see my previous post.
Please let me know if I'm addressing the wrong group here.
Thanks
Christoph
Christoph Baudson (WhereGroup) schrieb:
Hello,
this is Christoph from Mapbender. Thanks to Howard for setting up our accounts; now I have a question about installing PostgreSQL on the Telascience server.
I ran "sudo yum install postgresql" and the installation completed, but there were two errors (I have attached a log file).
According to "sudo rpm -qa |grep post":
postfix-pflogsumm-2.2.2-2
postgresql-8.0.8-1.FC4.1
postfix-2.2.2-2
postgresql-libs-8.0.8-1.FC4.1
postgresql seems to be installed. But there is no start script in /etc/init.d/.
Do you know what might be wrong?
Thanks
Christoph
Baudson Christoph
http://www.wheregroup.com
[christoph@xblade10-2 /]$ sudo yum install postgresql
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
Password:
Setting up Install Process
Setting up repositories
updates-released 100% |=========================| 951 B 00:00
extras 100% |=========================| 1.1 kB 00:00
base 100% |=========================| 1.1 kB 00:00
Reading repository metadata in from local files
Parsing package install arguments
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package postgresql.i386 0:8.0.8-1.FC4.1 set to be updated
--> Running transaction check
--> Processing Dependency: libpq.so.4 for package: postgresql
--> Restarting Dependency Resolution with new changes.
---> Package postgresql-libs.i386 0:8.0.8-1.FC4.1 set to be updated
Dependencies Resolved
Package Arch Version Repository Size
Installing:
postgresql i386 8.0.8-1.FC4.1 updates-released 2.6 M
Installing for dependencies:
postgresql-libs i386 8.0.8-1.FC4.1 updates-released 184 k
Transaction Summary
Install 2 Package(s)
Update 0 Package(s)
Remove 0 Package(s)
Total download size: 2.8 M
Is this ok [y/N]: y
Downloading Packages:
(1/2): postgresql-libs-8. 100% |=========================| 184 kB 00:00
(2/2): postgresql-8.0.8-1 100% |=========================| 2.6 MB 00:29
Running Transaction Test
error: failed to stat /mnt/data3: Permission denied
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
Installing: postgresql-libs ######################### [1/2]
Installing: postgresql ######################### [2/2]
Installed: postgresql.i386 0:8.0.8-1.FC4.1
Dependency Installed: postgresql-libs.i386 0:8.0.8-1.FC4.1
Complete!
Sac mailing list
Sac@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/sac
