-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
the Mapbender project has added the requirements of the Mapbender VM to
the transition plan[1].
The old telascience server has been offline for more than a week. This
is turning into a major blocker for development. With most of the demos
down it also reflects badly on the project. There is a ticket [2] which
also applies for MapServer tutorials and GeoNetwork demo server both
have been running on the same dead telascience blade.
Arnulf.
[1]
http://wiki.osgeo.org/wiki/Infrastructure_Transition_Plan_2010#osgeo3_.26_osgeo4
[2] http://trac.osgeo.org/osgeo/ticket/566
Tyler Mitchell (OSGeo) wrote:
Following up from my last note. Can you see below (Markus has same
troubles) - and add your thoughts for a mapbender virtual machine - hard
drive and memory requirements, so we can get you started on a migration
ASAP...Tyler
-------- Original Message --------
Subject: Re: [SAC] Preparation of GRASS VM?
Date: Sun, 02 May 2010 23:07:35 -0700
Reply-To: tech@wildintellect.com, System Administration Committee
Discussion/OSGeo <sac@lists.osgeo.org>
To: System Administration Committee Discussion/OSGeo <sac@lists.osgeo.org>Markus Neteler wrote:
Hi SAC,
since the OS on xblade14 is pretty old, we are having increasing troubles
to keep stuff running.
Would it be possible to obtain the "template" VM in order to start
with the
preparation for the migration?thanks
MarkusPlease fill out an entry in the table with the hard drive requirements
for such a VM.
http://wiki.osgeo.org/wiki/Infrastructure_Transition_Plan_2010#Final_PlanI'll add it to the set of VMs that will likely be made this week.
Alex
Sac mailing list
Sac@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/sac
Arnulf Christl
President OSGeo
http://www.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkvf6hIACgkQXmFKW+BJ1b2fVgCfTTCk9ZjQXnzYCtDvFSloAm2i
UqAAn3yYObSMumV0tXYDdqvNxKBPy7IN
=sMfR
-----END PGP SIGNATURE-----
