Hi, I've started to slowly migrate the "projects" VM to Squeeze
backports in order to reduce the impact of the next dist-upgrade to
Wheezy. I took care *not* to touch critical pieces like Trac, PostGIS
or GIT but I'm planning to upgrade these as well in the medium term.
Please shout if you encounter unexpected behaviou on the "projects" VM.
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Cmake updated on "projects" VM from 2.8.2 to 2.8.9, please test, if
you're using it,
Martin.
Some Perl and Python modules and GIT updated on "projects" VM as well,
Martin.
If nobody objects, I'd remove the "trac" distro package from the
"projects" VM.
Martin.
"projects" VM.
Done, please test your Python stuff for missing dependencies.
Martin.
