It looks like we can accomplish this with a new VirtualHost clause in
/etc/apache2/sites-available/docs.geotools.org.conf or I suppose
better a new old.geotools.org.conf in that directory. I presume we
also need to update pairnic to point old.geotools.org to this server?
Is there a corresponding SAC ticket? Or shall I just try and go ahead
and implement this?
Best regards,
Frank
On Wed, Mar 25, 2015 at 5:27 PM, Jody Garnett <jody.garnett@gmail.com> wrote:
Quick question about docs.geotools.org and how it is published.
The directory /osgeo/geotools/htdocs is used by several scripts to unpack
generated documentation for publication.
I have unpacked an html export of the codehaus wiki to
/osgeo/geotools/htdocs/wiki and would like to make this available ... as
old.geotools.org
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Software Developer
and implement this?
On Thu, Mar 26, 2015 at 5:22 PM, Jody Garnett <jody.garnett@gmail.com> wrote:
I have not made a trac ticket as I was hoping to learn how to do this -
course reading your reply I am now intimidated and wonder what pairing is
Jody,
Ah, you would like to do it. It should be quite easy. I see you already have
sudo access.
You should be able to copy /etc/apache2/sites-available/docs.geotools.org.conf
tp /etc/apache2/sites-available/old.geotools.org.conf and then edit it in ways
that are hopefully fairly obvious.
After that make sure there is a soft link to it in the
/etc/apache2/sites-enabled directory (see the others for examples).
After that you should be able to restart apache like:
/usr/sbin/apache2ctl graceful
It won't work till the old.geotools.org domain is setup under
geotools.org. Our domain registrar is "pairnic". I'll try to do that
part right now, and let you know.
On 25 March 2015 at 19:44, Frank Warmerdam <warmerdam@pobox.com> wrote:
Jody,
and implement this?
Best regards,
Frank
> unpack
> old.geotools.org
> Jody Garnett
> Sac mailing list
> Sac@lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/sac
warmerdam@pobox.com
Jody,
sudo access.
It won’t work till the old.geotools.org domain is setup under geotools.org. Our domain registrar is “pairnic”. I’ll try to do that
and implement this?
