On 12/09/2010 01:53 PM, Hamish wrote:
activityworkshop wrote:
Very cool, great job!
thanks, luckily we have the adhoc server to play with.
Just a question about the images, it seems to have
ignored the image formatting options like:
:scale: 50 %
:align: rightright, I saw that but wasn't sure if the layout had changed in
the control files or not. guess not.so such images which should be small and on the right
are huge and on the left. Those images are properly
sized/aligned in the docs on the DVD, and when I built the
docs using the OSGeo Live DVD, it didn't have that problem
either. Maybe it's a sphinx version thing, or maybe a
stylesheet thing?Cameron wrote:
I think this would be a sphinx version problem, which has
been noticed before by people running debian,the problem we (ie Jody and myself) saw before was older versions
of sphinx choking the "%" in "scale: 50 %". This is something
different..(adhoc.osgeo.osuosl.org is running debian 5.0.4). I
understand that debian has an older version of sphinx than
on ubuntu 10.04 that we run on osgeo-live.yes, but someone installed the latest sphinx 1.0.4 on the server,
On December 5 Hamish wrote:
sphinx there will be version 1.0.4. (who's been installing
custom stuff to /usr instead of /usr/local on the server?
grumble)so it is running that not the 0.4.2 that comes with Lenny.
FWIW, sphinx 0.6.3 and 0.6.6 are available for Lenny from
the backports.org debian repositories. Ubuntu/Lucid shipped with
version 0.6.4.I wonder if sphynx changed the syntax on us or if it's a bug in
the bleeding edge version? or...?I'll look into a user-space parallel of sphinx 0.6.. mmmph
Hamish
Backports should be enabled on that server(adhoc), it shouldn't be a big
issue to install from there. Though we might want to check if anyone
else on adhoc is using sphinx before upgrading it.
I noticed it back when we built the last DVD, and think it's just a
change in sphinx and we should just go with the newer version.
Alex
