Christoph Baudson (WhereGroup) wrote:
More questions:
How is the status of a bug tracker at OsGeo?
Christoph,
I'm prepared to work with anyone from the Mapbender team on preparing a
"Trac" instance for Mapbender at OSGeo now. There will be at least one
more change with how urls are setup for Trac services in the next week or
two so I would suggest we just get the setup going now, but not actually
put it into use till that change is completed.
Trac instances for OSGeo, MapGuide and FDO are workingly fairly smoothly now.
If the Mapbender PSC would like to select someone to work with me on it, I
can get going.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
Thank you, Frank. I suggest you notify mapbender_dev once the setup of trac is completed, then we can get the Mapbender trac running in one go; I guess we can wait a week or two.
Christoph
More questions:
Christoph,
can get going.
Best regards,
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:info@wheregroup.com
http://www.wheregroup.com
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Baudson Christoph
