#165: Wiki LDAP integration
Reporter: crschmidt | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Resolution: | Keywords:
Comment (by martin):
All PHP-related packages that were shipped with the distribution on
'osgeo2' have been removed. Such script was used to configure PHP:
./configure --prefix=/usr/local --with-apxs2=/usr/sbin/apxs \
--disable-cgi --with-openssl --with-gettext --with-ldap \
--with-readline --with-pdo-pgsql --with-pgsql \
--with-mysql --with-pdo-mysql --with-mysql-sock=/var/lib/mysql/mysql.sock
--without-pdo-sqlite --without-sqlite --with-xmlreader --with-xsl \
--with-gd --with-jpeg-dir --with-png-dir --with-zlib-dir --with-bz2 \
--with-ttf --with-freetype-dir \
--enable-sysvshm=yes --enable-sysvsem=yes --enable-memory-limit
Wiki database access parameters can be read from the "LocalSettings.php"
file. We're running MySQL here, so the GRANT for database access looks a
bit funny:
mysql> GRANT all on osgeo_wiki to 'wiki'@'localhost';
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/165#comment:2>
OSGeo <http://www.osgeo.org/>
