#251: Log problems on osgeo.org
Reporter: marie | Owner: sac@lists.osgeo.org
Type: defect | Status: new
Priority: critical | Component: SAC
Resolution: | Keywords: drupal ldap
Changes (by wolf):
* owner: wolf => sac@lists.osgeo.org
* component: WebSite => SAC
Comment:
The root of the problem is the LDAP server and its SSL configuration.
Drupal is unable to connect to it via SSL.
Reassigning to SAC
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/251#comment:3>
OSGeo <http://www.osgeo.org/>
How does the error message look like, which part is failing here,
encryption or authentication ?
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
I'd say it is the encryption that fails:
The error message is:
ldap_start_tls(): Unable to start TLS: Connect error in /var/www/html/sites/osgeo.org/modules/ldap_integration/ldap_integration/LDAPInterface.php on line 129.
LDAP Bind failure for user. Error -1: Can't contact LDAP server
and
Could not start TLS. (Error -11: Connect error).
--Wolf
On 29.04.2008 21:16, Martin Spott wrote:
Martin.
<:3 )---- Wolf Bergenheim ----( 8:>
on line 129.
Well, to my experience the 'usual' cause for LDAP SSL/TLS connection
to fail is an expired SSL certificate,
Martin.
