#347: PostGIS SVN post-commit hooks
Reporter: pramsey | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Resolution: | Keywords: svn
Changes (by pramsey):
* cc: kneufeld (added)
Comment:
Kevin Neufeld writes:
Now that we are fully moved over to the osgeo SVN and I've had a chance to
rebuild our autobuild environment, I need a couple of SVN hooks installed.
When the svn was hosted here, I installed a couple of post-commit hooks
that automatically triggered several test builds/regression tests/pdf
generatation/etc... after every commit.
I can I please get someone to install something similiar on the new
svn.osgeo.org/postgis repo?
i.e., something like this in post-commit:
if svnlook dirs-changed /home/svn/repositories/postgis | grep trunk
>/dev/null 2>&1; then
/usr/bin/wget -O - -q -b http://office.refractions.net:8082/job/
PostGIS-trunk-build/build?token=build_it
fi
if svnlook dirs-changed /home/svn/repositories/postgis | grep branches
PostGIS-branch-build/build?token=build_it
fi
WKTRaster-trunk-build/build?token=build_it
fi
(this will trigger independent builds for the PostGIS branch and trunk as
well as the WKTRaster project).
At the moment, the reference buildfarm is polling the branch and trunk
directories for changes ... I'd think it'd be better to move this to a
push operation.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/347#comment:6>
OSGeo <http://www.osgeo.org/>
