#368: request to upgrade svn server to support mergeinfo
Reporter: mbedward | Owner: sac@lists.osgeo.org
Priority: normal | Component: SAC
Resolution: | Keywords: svn server
Comment (by hobu):
I support doing the upgrade of this if someone could research the
following:
- We have 32 repositories. Can the server software be upgraded from 1.4.2
to 1.5 without full dump/restore when using FSFS as the storage type?
- What happens to a mirror (http://svnmirror.osgeo.org/) that is using an
older version of subversion? Must it be upgraded at the same time?
- Do the 1.5 subversion bindings work with Trac 0.10?
Howard
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/368#comment:5>
OSGeo <http://www.osgeo.org/>
