Can you provide input on this from the SAC perspective? Specifically whether SAC wants to run something like this and which one if there is a technical preference?
Best regards, Eli
I'd like to see a more complete comparison of options, and little more info on expected usage based on previous numbers, and future anticipated expansion. https://alternativeto.net/software/mailchimp/
Noting things like Campyn has a 15% non-profit discount and a pay-as-you-go option.
LAMP stack is pretty straightforward, we do not at this time have an AWS account. Not saying it's out of the question but it's more complexity than one might think to maintain access/persmissions, billing tags, etc... Might even opt to use a pre-built AWS lightsail LAMP to even skip on most of the setup work.
Per usual if someone not currently on SAC is interested in becoming the admin that would add weight to any self hosted options.
