On Sat, Oct 07, 2017 at 10:04:19AM +0200, Jürgen E. Fischer wrote:
Hi Martin,
On Fri, 06. Oct 2017 at 21:01:20 +0000, Martin Spott wrote:
> Aside from this extra delivery last weekend: The consequence from getting a
> bulk of meaningless messages every hour these days will be that I will -
> again - create a filter to route all these messages into a separate folder
> or to /dev/null
> I'm sure this wasn't the intended purpose.
Of course not - the service producing the messages should obviously have been
adjusted to not produce those useless messages.
Someone with access on webextra or backup should do that.
Can you ssh into webextra ? I don't see your username in passwd.
Mails from bacula I remember already getting them (or maybe they
were only from the server side?). The bacula configuration on
the server side is under a local git repository, would it help
if I pushed that into a private Gogs repository for review ?
I wouldn't know how to reduce verbosity of those mails to just
receive urgent ones (errors or warnings).
As per postfix changes (probably unrelated to the added noise),
they don't have a clear effect to me. For example, this one:
myhostname = lists.osgeo.org
-myorigin = $myhostname
+myorigin = osgeo6.osgeo.osuosl.org
Why was this change needed ? How does it affect mail delivered by
mailman ?
And later, adding backup.osgeo.osuosl.org to mydestination, why
was it needed ? Does it go togheter with the addition of
`bacula: root` alias ?
Other safe changes should probably just be committed as they are
(welcome to mantra whisperers, btw!)
--strk;
