Hi: the OSGeo Catalogue Interoperability Working Group [1] is working
on defining a open, harmonized set of link type identifiers [2] for
use across catalogue implementations. The idea here is that link types
are identified in a unified fashion so clients can work with
catalogues and be able to add data or services dynamically and with
significantly less heuristics.
Our list in progress is at [2].
Part of this includes a dereferencing endpoint for applications that
really need/want to resolve what the link type identifiers are really
referring to. This dereferencing endpoint will basically be a thin
front end to bounce / redirect requests to accordingly.
We have a very simple, light Python Flask application [3] which we
would like to hang off the http://osgeo.org/vocab endpoint.
I hope this make sense. Suggestions to move this forward?
Thanks
..Tom
[1] http://wiki.osgeo.org/wiki/Cat-Interop
[2] https://github.com/OSGeo/Cat-Interop/blob/master/link_types_vocab.csv
[3] https://github.com/tomkralidis/Cat-Interop/tree/master/vocab
Tom,
Would you consider http://vocab.osgeo.org/ ?
If so, we could fairly easily set you up to do this on the webextra VM.
Best regards,
Frank
Thanks
…Tom
Sac mailing list
Sac@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/sac
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Software Developer
Frank: sorry for the delay. Yes, this would work. Thanks.
On Wed, Mar 5, 2014 at 10:19 PM, Frank Warmerdam <warmerdam@pobox.com> wrote:
Tom,
Best regards,
Frank
Thanks
..Tom
Sac mailing list
Sac@lists.osgeo.org
warmerdam@pobox.com
Sac mailing list
Sac@lists.osgeo.org
