FYI, and could someone please remove me as the admin contact for all of domains managed by the PairNIC account? I think they have a bulk-update function for this…
Jason
---------- Forwarded message ----------
Date: 3 May 2011 11:36
Subject: spatialreference.org down
To: Howard Butler <hobu.inc@gmail.com>, jason@jasonbirch.com
Hi Howard, Jason,
I’m contacting you because whois says you run/admin www.spatialreference.org, which is having some troubles right now:
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /.
Reason: Error reading from remote server
http://www.downforeveryoneorjustme.com/spatialreference.org
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
[http://environmentyukon.gov.yk.ca/geomatics/](http://environmentyukon.gov.yk.ca/geomatics/)
FYI I changed it for osgeo.org already, didn’t think about the others.
----- Original message -----
function for this…
Jason
Hi Howard, Jason,
Proxy Error
The proxy server could not handle the request *GET
/<http://www.spatialreference.org/>;
cheers,
matt wilkie
Geomatics Analyst
Faxhttp://environmentyukon.gov.yk.ca/geomatics/
Hi Jason,
I am wondering if you can add me as the admin for Nabble's OSGeo forum (http://osgeo-org.1803224.n2.nabble.com/) and MapServer forum (http://osgeo-org.1803224.n2.nabble.com/MapServer-f1969210.html)…or at the minimum just for the MapServer forum. Thanks.
-jeff
function for this...
Jason
Thank you!
You should be an admin there now if you’ve signed in with the same email.
On 4 May 2011 12:21, Jeff McKenna wrote:
Hi Jason,
I am wondering if you can add me as the admin for Nabble’s OSGeo forum (http://osgeo-org.1803224.n2.nabble.com/) and MapServer forum (http://osgeo-org.1803224.n2.nabble.com/MapServer-f1969210.html)…or…or) at the minimum just for the MapServer forum. Thanks.
-jeff
On 11-05-04 4:36 PM, Jason Birch wrote:
Thank you!
You should be an admin there now if you've signed in with the same email.
thanks, I see more items in the "Options" menu. works, thanks.
-jeff
