I've been using the new website VM for the FOSS4G site in Drupal. We've had a contractor helping with it and I'd like to give him ssh access, temporarily, to help out when I'm away next week. Any objections to setting him up?
Otherwise would someone be available for Peter Batty, FOSS4G chair, to contact in case he needs some help in my absence?
Tyler
On 11-06-14 01:56 PM, Tyler Mitchell wrote:
Hi all, I've been using the new website VM for the FOSS4G site in Drupal.
him up?
Tyler,
I have no objection to your temporarily granting someone else membership
in the SAC login group (needed for logs to the website VM) if you have
some confidence in them. You can do so at:
https://www2.osgeo.org/cgi-bin/auth/ldap_shell.py?group=sac
I notice that you were not in the SAC group and I took the liberty of
adding you too since it I can certainly imagine your needing access
sometimes. Were you able to login to the website vm without this? If
so perhaps I should investigate how that was working.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
Thanks. Yeah, I was already logging in as root via ssh key auth. Is that changing?
Tyer
Tyler,
Ah, that does work. I just don't consider it a normal means of access.
You should now be able to login using your normal OSGeo identification.
Best regards,
Tyler,
Cool, thanks - that works great!
