warmerdam@tracsvn:~$ sudo ls
[sudo] password for warmerdam:
sudo: PERM_ROOT: setresuid(0, -1, -1): Operation not permitted
sudo: unable to open /var/lib/sudo/warmerdam/0: Operation not permitted
sudo: unable to set supplementary group IDs: Operation not permitted
sudo: unable to execute /bin/ls: Operation not permitted
Any thoughts on something that may have changed resulting in this?
Best regards,
Frank
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Software Developer
Best regards,
Frank
There were some Debian upgrade quirks on other machines that broke sudo
once. Maybe this is similar. Note I think your ssh key is in the root
account so you could just login to that to work around this blocker for now.
[...] Maybe this is similar. Note I think your ssh key is in the root
Correct. I'll try to find out what's wrong this time.
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Martin.
On Sat, Apr 25, 2015 at 09:10:40PM -0700, Frank Warmerdam wrote:
I find I am unable to sudo on the Trac VM:
Fixed - please test,
Martin.
On Sun, Apr 26, 2015 at 12:26 PM, Martin Spott <Martin.Spott@mgras.net> wrote:
Martin.
Sac mailing list
Sac@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/sac
