Yes, I think your contributions warrant giving you sudo on all the
machines (though I think that means it's done 1 at a time).
Alex
-------- Forwarded Message --------
Subject: Sudo on projects and wiki (+ sbarnes removal)
Date: Mon, 1 Aug 2016 10:47:43 +0200
To: sysadmin@osgeo.org
Hi there, I found another "sbarnes" in sudo, on the "wiki" host,
where I also don't have sudo. So I came back to find the "sbarnes"
removal thread and found this mail where I asked
sudo for the "projects" host.
Can I have sudo on both "projects" and "wiki" now ?
That way I'll remove "sbarnes" and will be able to help
with wiki administration (see
https://trac.osgeo.org/osgeo/ticket/1767)
--strk;
On Tue, May 17, 2016 at 09:16:02PM +0200, Sandro Santilli wrote:
I don't have sudo on the "projects" machine, can I have it ?
--strk;
On Tue, May 17, 2016 at 09:14:16PM +0200, Sandro Santilli wrote:
> I've found and removed "sbarnes" from the 'adhoc' machine too,
> leaving:
> [adhoc]
> sudo:x:27:tmitchell,warmerdam,hobu,martin,wolf,crschmidt,neteler,aboudreault,arnulf,astrid_emde,kmq,jmckenna,dmorissette,sderle,hamish,tbonfort,wildintellect,tomkralidis,strk
> --strk;
> On Mon, May 16, 2016 at 05:58:32PM +0200, Sandro Santilli wrote:
> > On Mon, May 16, 2016 at 08:30:37AM -0700, Alex Mandel wrote:
> > > Sure, we should also make sure to add you at the same time.
> > sbarnes removed from sudo group on "tracsvn", "web" and "secure"
> > machines, which are the only ones on which I have "sudo"
> > Left over:
> > [tracsvn]
> > sudo:x:27:tmitchell,warmerdam,hobu,martin,wolf,crschmidt,neteler,aboudreault,pborissow,maphew,wildintellect,strk
> > [web]
> > sudo:x:27:tmitchell,warmerdam,hobu,martin,wolf,crschmidt,neteler,aboudreault,jharahush,jgrocha,dwaetjen,ian,wildintellect,jmckenna,arnulf,strk
> > [secure]
> > sudo:x:27:tmitchell,warmerdam,hobu,martin,wolf,crschmidt,neteler,aboudreault,wildintellect,strk
> > I noticed the /etc/gshadow file only matches on the "secure" machine,
> > while others don't have most of the names, should that be also fixed ?
> > --strk;
