If you would like this disk replaced, you will need to send a replacement to the shipping address listed at http://osuosl.org/contact. Please let us know if you have any questions.
Sean
Sean Rettig
Student Systems Engineer
OSU Open Source Lab
At that price we should probably just get it ordered and shipped to OSL
without hesitating. I'm not sure if the machine will need to be brought
down to rebuild the RAID or not once they get the drive.
Probably not.
Who will order the disk?
thanks
Last year it was Daniel M.. Not sure if the board has shuffled roles.
Quick note, we do have the option to buy a bigger drive and if we did so
for each drive as they go out or we feel the need the disk space of the
machine would increase once all 6 original drives are swapped out for
bigger drives.
2014-03-04 1:06 GMT+01:00 Alex Mandel <tech_dev@wildintellect.com>:
On 03/03/2014 03:36 PM, Markus Neteler wrote:
> On Tue, Mar 4, 2014 at 12:33 AM, Alex Mandel <tech_dev@wildintellect.com>
wrote:
>> On 03/03/2014 03:09 PM, Sean Rettig via RT wrote:
>>> Hello OSGeo Team,
>>> We noticed that disk 3 has failed in osgeo4.osuosl.bak, and the
warranty seems to be expired:
>>> http://www.dell.com/support/my-support/us/en/04/product-support/servicetag/H87NZL1?show_warranty_modal=true
>>> Thanks,
>>> Sean
>> SAC,
>> This system is setup RAID 6 so loss of 2 drives is tolerated. Looking
>> quickly I believe this is the correct replacement option.
>> http://www.amazon.com/Seagate-Cheetah-15000RPM-Internal-ST3300657SS/dp/B0035G0J98
>> $74 usd
>> without hesitating.
> +1 since it is used for our
> http://wiki.osgeo.org/wiki/ProjectsVM
> Probably not.
> thanks
> Markus
bigger drives.
Alex
Hi SAC,
I think Daniel M is out of the office until next week, but this week we
have a board meeting and maybe other board can do the order if you have a
clear proposal.
a clear proposal.
Good point Jorge. Maybe a SAC rep could attend the Board IRC meeting
this Thursday and discuss SAC budget needs for 2014 (or edit the wiki
page directly http://wiki.osgeo.org/wiki/OSGeo_Budget_2014).
I do not think there is any need for Board deliberation on a $74 purchase of a hard drive. This falls within the existing SAC budget item (though small hardware purchases were not specifically mentioned).
In my opinion, there is no reason for SAC not to proceed. Given that Daniel holds the credit card it may be necessary to have him issue the order.
Best regards,
Frank
On Tue, Mar 4, 2014 at 1:38 AM, Jorge Sanz <jsanz@osgeo.org> wrote:
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Software Developer
I’m not sure if the machine will need to be brought
Probably not.
thanks
Last year it was Daniel M… Not sure if the board has shuffled roles.
bigger drives.
Alex
Hi SAC,
I think Daniel M is out of the office until next week, but this week we have a board meeting and maybe other board can do the order if you have a clear proposal.
Sean
Sean,
Thanks for the notice. We're looking into ordering a replacement and
will notify you when it ships.
2014-03-04 18:22 GMT+01:00 Frank Warmerdam <warmerdam@pobox.com>:
Jorge,
order.
Best regards,
Frank
Sure sorry, I was trying to channel the order taking the chance that we
meet, and maybe someone apart from Daniel can do it, not that the Board has
to approve that cost at all.
If that can ve resolved now, better than tomorrow.
Sean
Sean,
On Sat, Mar 1, 2014 at 8:17 PM, Daniel Morissette wrote:
... but unfortunately I will be off the grid until March 11 so I won't be
around for the board meeting next week...
I think only TylerM and Daniel have access to our accounts now. Might
be best for someone to use their personal credit card and Daniel can
reimburse you later.
I should also clarify that the drive that needs replacing appears to be a 3.5" 300GB 15k SAS drive.
-Sean
> Hello OSGeo Team,
questions.
> Thanks,
> Sean
Sean,
Just received it, and replaced the drive, and it's currently rebuilding. Should be done shortly.
Thanks!
On Tue Mar 25 11:11:49 2014, tech@wildintellect.com wrote:
Sean,
Disk is on it's way.
Seagate Cheetah 15K.7 300 GB 15000RPM SAS 6 Gb/s 16MB Cache 3.5 Inch
Internal Bare Drive ST3300657SS
Your estimated delivery date is:
*Monday, March 31, 2014 -
Thursday, April 3, 2014 *
Alex
On 03/10/2014 09:03 AM, Sean Rettig via RT wrote:
> Alex,
> -Sean
>>> Hello OSGeo Team,
>> questions.
>>> Thanks,
>>> Sean
>> Sean,
and
>> Thanks,
>> Alex
>> OSGeo Sys Admin Committee Chair
> Sac mailing list
> Sac@lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/sac
