The VPN access for Martin Spott is just about done. I just need his public key,
and then for him to test it all out. He already has VPN access so I've added
access to osgeo3 and 4 for that.
Taylor Fahlman
Student Systems Engineer
Open Source Lab
On Mon Feb 02 12:23:30 2015, jldugger wrote:
Extracted from #24234: "Make sure Martin Spott knows how to use his
new access of osgeo3 and
osgeo4 OS."
Do you want me to send an SSH or GnuPG key ?
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
On Sun Feb 15 15:58:41 2015, Martin.Spott@mgras.net wrote:
Hi Taylor,
public key,
I've added
On Mon, Feb 16, 2015 at 10:12:56AM -0800, Taylor Fahlman via RT wrote:
I will need an SSH key.
Voila,
Martin.
Okay, you should be ready to go! The next step is to use your vpn access to
login into osgeo3 and 4 with the username martins, and let me know how that
goes. You local password for sudo should be in your home directory.
Let me know if you can login
Taylor Fahlman
Open Source Lab
I still have the OpenVPN stuff installed on one machine and will try to
get it to work again. I'll keep you posted .... ah, wait, I need to
know the IP addresses of these two VM hosts.
Thanks a lot so far !
Martin.
Martin.
