On Mon Feb 16 11:35:07 2015, Martin.Spott@mgras.net wrote:
On Mon, Feb 16, 2015 at 11:16:24AM -0800, Taylor Fahlman via RT wrote:
> Okay, you should be ready to go! The next step is to use your vpn
access to
> login into osgeo3 and 4 with the username martins, and let me know
how that
> goes. You local password for sudo should be in your home directory.
I still have the OpenVPN stuff installed on one machine and will try
to
get it to work again. I'll keep you posted .... ah, wait, I need to
know the IP addresses of these two VM hosts.
Worksforme !
.... herewith I confirm: "osgeo4" is dead slow - ah, you already knew
that !?
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Worksforme !
that !?
Martin.
Well, it's still down a drive, so it's running in degraded mode. We're
expecting to coordinate a time to initiate a rebuild, based on OSGEO's
demand profile. Thoughts?
On Mon, Feb 16, 2015 at 1:10 PM, Martin Spott via RT <support@osuosl.org> wrote:
Worksforme !
that !?
Martin.
Since I doubt we can slow the rebuild, we should probably shoot for a
Friday afternoon/evening or Saturday PST. Hmm, Adhoc is in use heavily
until end of next weekend. So something the week of Feb 23 might work
that way we can turn off Adhoc like we did last time.
I'll need to check-in with QGIS too since they are about to do a release
and that might add considerable traffic too.
Alex
Worksforme !
that !?
Martin.
Alex
Worksforme !
that !?
Martin.
As mpsott has confirmed VPN / ganeti node access, I'm going to close this ticket, and follow up on disk maintenance on #24790.
release
Alex
We're
OSGEO's
>> Worksforme !
knew
>> that !?
>> Cheers,
>> Martin.
friends are !
Justin Dugger
Senior System Administrator
OSU Open Source Lab
