Folks,
Probably it's a well-known document, but I just found it helpful myself.
This is a SVN best practice doc by Apache Team:
http://www.apache.org/dev/version-control.html
Last FAQ is interesting:
"How frequently can I run a cron that connects to the repository?"
Recently, we have experienced irresponsiveness problems with SVN/Trac.
Perhaps it would be reasonable to check if OSGeo projects
do not run cron jobs against SVN repos too often.
Greetings
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Mateusz Loskot wrote:
Folks,
Mateusz,
It is possible to see active connections to svn, trac, Drupal and other
http services at:
http://svn.osgeo.org/server-status
I have seen long running svn transactions (MKACTIVITY for instance). I
might be interested to keep an eye on this aspect when the system is having
troubles.
Unfortunately, from the server-status report is hard to tell the difference
between an active connection that is stalled due to system load or a very slow
pipe back to the caller, and long lasting connections that are actually doing
a lot of work.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
