I've noticed that the trac backup machinery only backups trac instances
that are listed in a file (/osgeo/projects), but that file does not
include all the available trac instance.
In particular these are missing:
- el | https://trac.osgeo.org/el
- geomoose | https://trac.osgeo.org/geomoose
- gittest | https://trac.osgeo.org/gittest
The wiki page documenting how to create a new instance does not
mention updating that file (/osgeo/projects) so I guess it's easy
for it to end up out-of-sync:
https://wiki.osgeo.org/wiki/Trac_Instances#Creating_a_trac_instance
Do you know which other script uses that file ?
When I needed a list of trac instances I created a
/var/www/trac/trac_instances.txt and used it from
some scripts in /osgeo/tools/trac/ - do you see any
problem in using this new one instead of /osgeo/projects ?
I find it more clear as a name since not all OSGeo projects
use trac...
Is there any reason to leave some trac instances out of
the backup or should bacula simply backup all instances ?
(I think it should back them all up)
NOTE: the page shown at the https://trac.osgeo.org page is
manually edited so has yet another view of available instances,
could be turned to use the official list of instances.
--strk;
