As I prepare to make a full hotcopy backup of all trac instances
in order to upgrade Trac to 1.2, I found what look like being
old backups under the trac environments directories, like these:
Those two (but there are similar in all other envs) are from
April 2015 and May 2016, do you know what/who created them and
why ?
I'm assuming actual backups live elsewhere (different machine)
but can anyone confirm that ?
--strk;
I have seen a cron script to create backups. Only Martin (or someone checking the bacula config) could confirm that those are making it to the Backup machine.
> ubuntugis/db/postgres.21.1429742384.bak.gz
> ubuntugis/db/postgres.29.1462395524.bak.gz
>why ?
Where have you seen that ?
I've searched in root's crontab and in /etc/cron.* but not found any
Backup machine.
On TracsvnVM the /etc/bacula/ directory doesn't seem to contain
any interesting information. On the backup machine I can login but
don't have sudo powers, can you bless me there maybe ?
Backup machine.
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
> Backup machine.
Thanks, I could now login and see that the backup job runs daily.
Following the 3-steps procedure (with my eyes) I found code lines
that are likely to fail and thus produce an error, are those errors
logged by bacula director ? How/where can I read them ?
The file /var/log/bacula/bacula.log is very short and was last written
in 2014...
