SAC members please confirm you can see this:
https://git.osgeo.org/gogs/sac/tracsvn-etc-trac
It is the global trac configuration, shared among all
trac instances.
--strk;
trac instances.
--strk;
"404"
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
I can see it, after login.
Without login "404".
Christian
Am 23.05.2016 um 11:35 schrieb Sandro Santilli:
https://git.osgeo.org/gogs/sac/tracsvn-etc-tracIt is the global trac configuration, shared among all
trac instances.--strk;
Sac mailing list
Sac@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/sac
> https://git.osgeo.org/gogs/sac/tracsvn-etc-trac"404"
That's what you get unless you're logged in AND part
of the SAC group. Can you confirm you can see after login ?
--strk;
Works after logging in, but why am I supposed to log in just for
read-only access alias browsing a repo ?
Martin.
>> "404"
> of the SAC group. Can you confirm you can see after login ?Works after logging in, but why am I supposed to log in just for
Each repository can be configured to be either public or private.
In this case, it is a private repository. We can decide if we
want to make it public. Personally I'm creating configuration
repositories as private by default.
--strk;
Hi Sandro,
read-only access alias browsing a repo ?Each repository can be configured to be either public or private.
Were observing different approaches of securing sensitive information,
it seems to me. Personally I'd rather not put sensitive config
information into a world-wide remote-accessible repository at all -
particularly not using a frontend whose auth mechanism doesn't feature
a well-known good reputation.
Therefore I'd suggest: If it requires protection, don't put it online
anywhere, if it doesn't require protection, make the repo public.
Opinions ?
Martin.
"Don't put it online anywhere" would actually not be true.
It's really about how to protect access.
If it's not on the web it could still be accessed via ssh,
for example. Do you mean "don't make it available via http?"
or "don't make it available via Gogs" ?
I'd be ok with an ssh-only solution (gitolite is pretty good
for similar use cases ).
--strk;
Indeed, we're talking about networked computers .... but isn't this
nit-picking ?
Martin.
nit-picking ?
Yes and no. I'm basically asking what is exactly that you don't trust.
Is it the web, specifically ? Do you want to completely disable
HTTPS access to private repositories ?
--strk;
Am 23.05.2016 um 19:56 schrieb Sandro Santilli:
Anything and anybody! (No, just joking! But that's a good basic mindset for sysops, right?)
Basically: what you put out there on a web accessible server "is gone". No web based system is 100% secure... (Hacker, NSA, etc. will find a way if they really want the information).
> Do you want to completely disable HTTPS access to private repositories ?
If you ask me, no. But I see the concern raised, and would also not do it for configuration files with sensible infos like passwords. Though, I also see the benefits for collaboration...
Christian
