At present trac.osgeo.org is disfunctional:
Python Traceback
Traceback (most recent call last): File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 387, in dispatch_request dispatcher.dispatch(req) File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 191, in dispatch chosen_handler = self._pre_process_request(req, chosen_handler) File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 263, in _pre_process_request chosen_handler = f.pre_process_request(req, chosen_handler) File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py", line 73, in pre_process_request self.get_repository(req.authname) # triggers a sync if applicable File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py", line 101, in get_repository repos = self._connector.get_repository(rtype, rdir, authname) File "/usr/lib/python2.3/site-packages/trac/versioncontrol/svn_fs.py", line 260, in get_repository crepos = CachedRepository(self.env.get_db_cnx(), repos, None, self.log) File "/usr/lib/python2.3/site-packages/trac/versioncontrol/cache.py", line 34, in __init__ self.sync() File "/usr/lib/python2.3/site-packages/trac/versioncontrol/cache.py", line 56, in sync cursor.execute("SELECT value FROM system WHERE name='repository_dir'") File "/usr/lib/python2.3/site-packages/trac/db/util.py", line 51, in execute return self.cursor.execute(sql) File "/usr/lib/python2.3/site-packages/sqlite/main.py", line 244, in execute self.rs = self.con.db.execute(SQL) OperationalError: database is locked
This when attempting to access: https://trac.osgeo.org/qgis/
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
-Desktop GIS Book:
*http://desktopgisbook.com
"We work virtually everywhere"
Gary,
it's back - now functional:
Sat May 24 19:45:46 UTC 2008
Python Traceback
applicable File
-gary
Gary Sherman
*Geospatial Hosting
*Web Site Hosting
-Desktop GIS Book:
Sac mailing list
Sac@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/sac
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
