I've (hopefully) changed default trac activity notification
user preferences to NEVER notify the updater of a ticket
by mail. This was done by tweaking the [notification-subscriber]
section in `/etc/trac/trac-common.ini` and ensuring no override
existed in local environments (/var/www/trac/env/*/conf/trac.ini).
If anyone is against this change please raise a point now.
Rationale for the change is that the updater knows what she
did, so doens't really need a notification, and reduding
email traffic may generally help with load of TracSVN machine.
> by mail.
This change is not clear to me: which trac instances are affected? The
sentence above is not yet clear to me.
All instances are affected.
When you change a ticket you are now NOT notified (by default).
Other parties (owner, assignee, those in Cc, any always_cc address)
are all still notified.
If project trac instances are affected (how?) such change needs please
to be communicated before changing anything,e.g. through the
"projects" ML.
