for several days (longer?), the load average on trac is very high -
leading to slow response rates when using the server.
Any ideas how to optimize apache?
On Sat, Nov 05, 2016 at 06:15:01PM +0100, Markus Neteler wrote:
leading to slow response rates when using the server.Any ideas how to optimize apache?
I'm no expert, but whenever I tried to debug slowness I found it
useless that top(1) only shows "apache" w/out a way to tell which
service is actually keeping apache busy.
I suspect it's trac, being a big apache module, but I've no proof
of that.
One thing I know is that I enabled trac logging when I started looking
at trac, so it could be tried to disable it, see /etc/trac/* (it's
under git).
--strk;
service is actually keeping apache busy.I suspect it's trac, being a big apache module, but I've no proof
of that.
Looks like that, as it can be seen with strace:
strace -p `ps aux | grep apache | head -n 2 | tail -n 1 | cut -d' ' -f2`
Are we still running with mod_python or mod_wsgi? Might be time to move
to uwsgi or gunicorn with supervisord. They scale better.
Apache has an internal status page. This makes me wonder what email the
munin monitoring is supposed to hit and if we can setup a rule for load
to trigger email to SAC.
-Alex
of that.Looks like that, as it can be seen with strace:
Sac mailing list
Sac@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/sac
It took 'awk' here instead of 'cut' as the last snippet, but
thanks !
I see many lines like these:
stat("/usr/local/lib/python2.6/dist-packages/TracMetrixPlugin-0.1.8dev-py2.6.egg/subprocess", 0x7ffe903d3950) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/python2.6/dist-packages/TracMetrixPlugin-0.1.8dev-py2.6.egg/subprocess.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/python2.6/dist-packages/TracMetrixPlugin-0.1.8dev-py2.6.egg/subprocessmodule.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/python2.6/dist-packages/TracMetrixPlugin-0.1.8dev-py2.6.egg/subprocess.py", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/python2.6/dist-packages/TracMetrixPlugin-0.1.8dev-py2.6.egg/subprocess.pyc", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/python2.6/dist-packages/TracSectionEditPlugin-0.2.6-py2.6.egg/subprocess", 0x7ffe903d3950) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/python2.6/dist-packages/TracSectionEditPlugin-0.2.6-py2.6.egg/subprocess.so", O_RDONLY) = -1 ENOENT (No such file or directory)
As if trac needs to find files over and over again, shouldn't it be loaded
all in memory at once instead ? Maybe it's still running as a pure cgi ?
--strk;
Apache is using mod_python,
according to /etc/apache2/includes/trac_env.inc
which is included by every instance.
How to access it ?
No munin experience here, sorry
--strk;
Le samedi 05 novembre 2016 18:15:01, Markus Neteler a écrit :
I'm not sure if it is related but the GDAL Travis-CI instances experience a
lot of flake failures during the execution of the automated tests due to
timeouts on download.osgeo.org
ERROR 11: CURL error: Failed to connect to download.osgeo.org port 80:
Connection timed out
gdalinfo failed - unable to open
'/vsicurl/http://download.osgeo.org/gdal/data/ecw/spif83.ecw’.
I'm also experiencing locally very slow downloading on this file.
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
> to uwsgi or gunicorn with supervisord. They scale better.Apache is using mod_python,
which is included by every instance.> Apache has an internal status page.
How to access it ?
Getting back to this.
Alex, did you receive my mail ?
Anyone knows what's the internal status page he's talking about ?
--strk;
which is included by every instance.Apache has an internal status page.
How to access it ?
Anyone knows what’s the internal status page he’s talking about ?
Perhaps this one?
http://trac.osgeo.org/server-status
–strk;
Sac mailing list
Sac@lists.osgeo.org
> > How to access it ?
> Anyone knows what's the internal status page he's talking about ?Perhaps this one?
Forbidden.
PS: does anyone know how to contact Alex in real-life ?
--strk;
How to access it ?
Forbidden.
--strk;
I am trying to keep up with the volume of email. The internal status
page for security reasons is likely only accessible via localhost. This
is standard Apache stuff. I stand by my recommendation to simply move
from mod_python to other methods of running trac. Though checking to
make sure the load is legitimate is good.
Alex
Trac seems down for me again.
-jeff
On 2016-11-05 2:15 PM, Markus Neteler wrote:
Resolved.
-jeff
-jeff
