Trac/SVN services are down. The problem VM seems to be "TracsvnVM" https://wiki.osgeo.org/wiki/TracsvnVM
-jeff
Jeff McKenna
President Emeritus, OSGeo Foundation
http://wiki.osgeo.org/wiki/Jeff_McKenna
-jeff
Jeff McKenna
I cannot access tracsvn(dot)osgeo(dot)osuosl(dot).org I will request a reboot of this VM from the OSUOSL team.
-jeff
https://wiki.osgeo.org/wiki/TracsvnVM-jeff
On Jan 6, 2017 4:10 PM, “Jeff McKenna” <jmckenna@gatewaygeomatics.com> wrote:
Maybe just the internet connection is down? It happened a few times recently.
recently.
Could be. But they didn't announce issues through their announce list or IRC or Twitter. I've been given a ticket ID for this.
-jeff
The OSUOSL team rebooted the tracsvn VM. Trac/SVN back online.
-jeff
2017-01-06 17:25 GMT+01:00 Jeff McKenna <jmckenna@gatewaygeomatics.com>:
thanks! Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
From the logs it seems that Apache and fail2ban were both killed by the
OOM Killer between 06:28 and 06:49 PST (should be UTC-8).
Not sure what was going wrong.
--strk;
> The OSUOSL team rebooted the tracsvn VM. Trac/SVN back online.From the logs it seems that Apache and fail2ban were both killed by the
OOM Killer between 06:28 and 06:49 PST (should be UTC-8).Not sure what was going wrong.
Looking at the server today, as it was being slow, I see
requests taking lots of CPU time made to these trac.osgeo.org
URI:
/mapguide/browser/trunk?rev=9112&format=zip HTTP/1.1
/mapguide/browser/trunk?rev=5605&format=zip HTTP/1.1
The first one results in ~40MB of transfer and is requested
multiple times per minute by the same IP with no Referer and
a MSIE 7.0 user agent.
Should we disable zip downloads ?
https://groups.google.com/forum/#!topic/trac-users/pWXR6Ib59NM
--strk;
URI:/mapguide/browser/trunk?rev=9112&format=zip HTTP/1.1
/mapguide/browser/trunk?rev=5605&format=zip HTTP/1.1The first one results in ~40MB of transfer and is requested
That could be solved with a fail2ban filter.
Please no.
At least not for all trac instances. AFAIK the GRASS GIS add-on management needs it.
> a MSIE 7.0 user agent.That could be solved with a fail2ban filter.
Could you give it a try ?
The logs show that the transfer size is different for the different
downloads, so maybe the client interrupts before end of operations
--strk;
.. this case we cannot catch. AFAIK we could only block that IP.
Perhaps not what we want?
