-------- Forwarded Message --------
[Deprecation Notice] - Container-Based Linux Build Environment Starting today, we will begin routing all Linux builds to the virtual-machine-based infrastructure.
Deprecation: Container-Based Linux Build Environments
Hi OSGeo!
We’re emailing to make sure you know about the ongoing deprecation of the container-based Linux build environment. As we have communicated on the blog <https://travis-ci.us7.list-manage.com/track/click?u=8ce724a4c9af4dace663cd39c&id=b8a008fb72&e=a07bfadf03>, and our changelog <https://travis-ci.us7.list-manage.com/track/click?u=8ce724a4c9af4dace663cd39c&id=c14e98036e&e=a07bfadf03>, we are now routing all Linux builds to the virtual-machine-based Linux infrastructure (“sudo: required” infrastructure). We believe this change facilitates a more intuitive build configuration experience that is more in line with how the majority of our customers and community use Travis CI.
Starting today, we will begin routing all Linux builds to the virtual-machine-based infrastructure, regardless of the setting for the sudo keyword in a .travis.yml file. We expect minimal impact to your builds, unless you specifically safelist Travis CI IPs as part of your CI/CD pipeline. If so, we recommend you update those values (see the docs <https://travis-ci.us7.list-manage.com/track/click?u=8ce724a4c9af4dace663cd39c&id=1a7aa66104&e=a07bfadf03> for the new IPs to use). The virtual-machine based environment has all the same tools as the container-based environment, along with better compute resources and support for building Docker containers.
We’re contacting you directly as it looks like you have at least one repository that ran a build within the last week on your open- and/or closed-source projects, where the build configuration is explicitly configured for the container-based build environment. This build configuration(s) may potentially be affected by this change, so we wanted you to be aware this change is happening. Your build traffic will be migrated automatically soon, or your can opt-in sooner by changing your .travis.yml(s) to use sudo: required.
Of course, if you have any questions at all, please feel free to contact us at support@travis-ci.com, or let us know on the community forum <https://travis-ci.us7.list-manage.com/track/click?u=8ce724a4c9af4dace663cd39c&id=b14087d1a6&e=a07bfadf03>\.
Happy building!
Thanks so much,
Travis CI Product Team
