I'd like to upgrade the OSGeo Trav VM tonight form Debian 5 to stable
Debian 7. Objectstions ? Anybody around to help fixing Trac issues
after the upgrade, if required ?
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Martin.
Yes I object. I'd prefer we have them (OSUOSL) reclone tracsvn2 and that
the upgrade is attempted on that VM and not the running Trac VM. Or we
can just attempt the update on tracsvn2 then update the db on it
ourselves to bring it up to date with the current VM and switch the
roles of the 2 VMs.
That way we can keep trac running while messing with updates.
On Sat, Jan 18, 2014 at 09:10:26AM -0800, Alex Mandel wrote:
Yes I object.
Ok,
Martin.
Yes I object.
Ok, I can offer upgrading one machine tonight, which one do you
recommend instead ? Trac is the only remaining machine running on
Debian 5 - and thus has been out of maintenance for months, that's why
I chose that one.
Martin.
Yes I object.
I chose that one.
Martin.
Let's turn on Tracsvn2 and you can do the upgrade to that one. If it
goes smoothly we can run the upgrade directly to Tracsvn or we can
migrate the db over to bring Tracsvn2 up to date. They have different IP
and can be run at the same time.
Ok, please do, is 140.211.15.133 correct ?
Martin.
