I have noticed recently that when I file a trac ticket (in the component Systems Admin for example), I don't get an email notification.
Can someone verify that in our trac.ini settings the following is set?
[notification]
always_notify_owner = true
always_notify_reporter = true
-jeff
To clarify: I don't receive an email notification when someone modifies a ticket that I had reported. -jeff
On 2015-06-19 9:09 AM, Jeff McKenna wrote:
[notification]
-jeff
On Fri, Jun 19, 2015 at 2:10 PM, Jeff McKenna
[notification]
Here the current situation:
neteler@tracsvn:~$ locate trac.ini | grep 'trac.ini$' | grep var |
xargs grep 'var\|always_notify_'
/var/www/trac/csmap/conf/trac.ini:always_notify_owner = true
/var/www/trac/csmap/conf/trac.ini:always_notify_reporter = true
/var/www/trac/csmap/conf/trac.ini:always_notify_updater = true
/var/www/trac/csmap/conf/trac.ini:repository_dir =
/var/www/svn/repos/metacrs/csmap
/var/www/trac/el/conf/trac.ini:always_notify_owner = true
/var/www/trac/el/conf/trac.ini:always_notify_reporter = true
/var/www/trac/el/conf/trac.ini:always_notify_updater = true
/var/www/trac/fdo/conf/trac.ini:always_notify_owner = true
/var/www/trac/fdo/conf/trac.ini:always_notify_reporter = true
/var/www/trac/fdo/conf/trac.ini:always_notify_updater = true
/var/www/trac/fdo/conf/trac.ini:repository_dir = /var/www/svn/repos/fdo
/var/www/trac/featureserver/conf/trac.ini:always_notify_owner = true
/var/www/trac/featureserver/conf/trac.ini:always_notify_reporter = true
/var/www/trac/featureserver/conf/trac.ini:always_notify_updater = true
/var/www/trac/featureserver/conf/trac.ini:repository_dir =
/var/www/svn/repos/featureserver/
/var/www/trac/fusion/conf/trac.ini:always_notify_owner = true
/var/www/trac/fusion/conf/trac.ini:always_notify_reporter = true
/var/www/trac/fusion/conf/trac.ini:always_notify_updater = true
/var/www/trac/fusion/conf/trac.ini:repository_dir = /var/www/svn/repos/fusion
/var/www/trac/gdal/conf/trac.ini:path = /var/www/gdal/htdocs
/var/www/trac/gdal/conf/trac.ini:always_notify_owner = true
/var/www/trac/gdal/conf/trac.ini:always_notify_reporter = true
/var/www/trac/gdal/conf/trac.ini:always_notify_updater = true
/var/www/trac/gdal/conf/trac.ini:repository_dir = /var/www/svn/repos/gdal
/var/www/trac/geoinformatica/conf/trac.ini:always_notify_owner = true
/var/www/trac/geoinformatica/conf/trac.ini:always_notify_reporter = true
/var/www/trac/geoinformatica/conf/trac.ini:always_notify_updater = true
/var/www/trac/geoinformatica/conf/trac.ini:repository_dir =
/var/www/svn/repos/geoinformatica
/var/www/trac/geomoose/conf/trac.ini:always_notify_owner = true
/var/www/trac/geomoose/conf/trac.ini:always_notify_reporter = true
/var/www/trac/geomoose/conf/trac.ini:always_notify_updater = true
/var/www/trac/geomoose/conf/trac.ini:repository_dir =
/var/www/svn/repos/geomoose
/var/www/trac/geonetwork/conf/trac.ini:always_notify_owner = true
/var/www/trac/geonetwork/conf/trac.ini:always_notify_reporter = true
/var/www/trac/geonetwork/conf/trac.ini:always_notify_updater = true
/var/www/trac/geoprisma/conf/trac.ini:always_notify_owner = true
/var/www/trac/geoprisma/conf/trac.ini:always_notify_reporter = true
/var/www/trac/geoprisma/conf/trac.ini:always_notify_updater = true
/var/www/trac/geoprisma/conf/trac.ini:repository_dir =
/var/www/svn/repos/geoprisma
/var/www/trac/geos/conf/trac.ini:always_notify_owner = true
/var/www/trac/geos/conf/trac.ini:always_notify_reporter = true
/var/www/trac/geos/conf/trac.ini:always_notify_updater = true
/var/www/trac/geos/conf/trac.ini:repository_dir = /var/www/svn/repos/geos
/var/www/trac/geotiff/conf/trac.ini:always_notify_owner = true
/var/www/trac/geotiff/conf/trac.ini:always_notify_reporter = true
/var/www/trac/geotiff/conf/trac.ini:always_notify_updater = true
/var/www/trac/geotiff/conf/trac.ini:repository_dir =
/var/www/svn/repos/metacrs/geotiff
/var/www/trac/ggl/conf/trac.ini:always_notify_owner = false
/var/www/trac/ggl/conf/trac.ini:always_notify_reporter = false
/var/www/trac/ggl/conf/trac.ini:always_notify_updater = true
/var/www/trac/ggl/conf/trac.ini:repository_dir = /var/www/svn/repos/ggl
/var/www/trac/grass/conf/trac.ini:path = /var/www/grass/htdocs
/var/www/trac/grass/conf/trac.ini:always_notify_owner = true
/var/www/trac/grass/conf/trac.ini:always_notify_reporter = true
/var/www/trac/grass/conf/trac.ini:always_notify_updater = true
/var/www/trac/grass/conf/trac.ini:repository_dir = /var/www/svn/repos/grass
/var/www/trac/kidsgis/conf/trac.ini:always_notify_owner = true
/var/www/trac/kidsgis/conf/trac.ini:always_notify_reporter = true
/var/www/trac/kidsgis/conf/trac.ini:always_notify_updater = true
/var/www/trac/mapbender/conf/trac.ini:php_path = /var/www/trac/php_cmd.sh
/var/www/trac/mapbender/conf/trac.ini:always_notify_owner = true
/var/www/trac/mapbender/conf/trac.ini:always_notify_reporter = true
/var/www/trac/mapbender/conf/trac.ini:always_notify_updater = true
/var/www/trac/mapbender/conf/trac.ini:repository_dir =
/var/www/svn/repos/mapbender
/var/www/trac/mapguide/conf/trac.ini:php_path = /var/www/trac/php_cmd.sh
/var/www/trac/mapguide/conf/trac.ini:always_notify_owner = true
/var/www/trac/mapguide/conf/trac.ini:always_notify_reporter = true
/var/www/trac/mapguide/conf/trac.ini:always_notify_updater = true
/var/www/trac/mapguide/conf/trac.ini:repository_dir =
/var/www/svn/repos/mapguide
/var/www/trac/mapserver/conf/trac.ini:always_notify_owner = true
/var/www/trac/mapserver/conf/trac.ini:always_notify_reporter = true
/var/www/trac/mapserver/conf/trac.ini:always_notify_updater = true
/var/www/trac/mapserver/conf/trac.ini:repository_dir =
/var/www/svn/repos/mapserver
/var/www/trac/mapserver-backup/conf/trac.ini:always_notify_owner = true
/var/www/trac/mapserver-backup/conf/trac.ini:always_notify_reporter = true
/var/www/trac/mapserver-backup/conf/trac.ini:always_notify_updater = true
/var/www/trac/mapserver-backup/conf/trac.ini:repository_dir =
/var/www/trac/metacrs/conf/trac.ini:always_notify_owner = true
/var/www/trac/metacrs/conf/trac.ini:always_notify_reporter = true
/var/www/trac/metacrs/conf/trac.ini:always_notify_updater = true
/var/www/trac/metacrs/conf/trac.ini:repository_dir = /var/www/svn/repos/metacrs
/var/www/trac/moss4g/conf/trac.ini:always_notify_owner = true
/var/www/trac/moss4g/conf/trac.ini:always_notify_reporter = true
/var/www/trac/moss4g/conf/trac.ini:always_notify_updater = true
/var/www/trac/moss4g/conf/trac.ini:repository_dir = /var/www/svn/repos/moss4g
/var/www/trac/openlayers/conf/trac.ini:always_notify_owner = false
/var/www/trac/openlayers/conf/trac.ini:always_notify_reporter = true
/var/www/trac/openlayers/conf/trac.ini:repository_dir =
/var/www/svn/repos/openlayers/
/var/www/trac/osgeo/conf/trac.ini:always_notify_owner = true
/var/www/trac/osgeo/conf/trac.ini:always_notify_reporter = true
/var/www/trac/osgeo/conf/trac.ini:always_notify_updater = true
/var/www/trac/osgeo/conf/trac.ini:repository_dir = /var/www/svn/repos/osgeo
/var/www/trac/osgeo4w/conf/trac.ini:always_notify_owner = true
/var/www/trac/osgeo4w/conf/trac.ini:always_notify_reporter = true
/var/www/trac/osgeo4w/conf/trac.ini:always_notify_updater = true
/var/www/trac/osgeo4w/conf/trac.ini:repository_dir = /var/www/svn/repos/osgeo4w
/var/www/trac/ossim/conf/trac.ini:path = /var/www/ossim/ossim-svn/doc/dox
/var/www/trac/ossim/conf/trac.ini:always_notify_owner = true
/var/www/trac/ossim/conf/trac.ini:always_notify_reporter = true
/var/www/trac/ossim/conf/trac.ini:always_notify_updater = true
/var/www/trac/ossim/conf/trac.ini:repository_dir = /var/www/svn/repos/ossim
/var/www/trac/postgis/conf/trac.ini:always_notify_owner = true
/var/www/trac/postgis/conf/trac.ini:always_notify_reporter = true
/var/www/trac/postgis/conf/trac.ini:always_notify_updater = true
/var/www/trac/postgis/conf/trac.ini:repository_dir = /var/www/svn/repos/postgis
/var/www/trac/proj/conf/trac.ini:always_notify_owner = true
/var/www/trac/proj/conf/trac.ini:always_notify_reporter = true
/var/www/trac/proj/conf/trac.ini:always_notify_updater = true
/var/www/trac/proj/conf/trac.ini:repository_dir =
/var/www/svn/repos/metacrs/proj
/var/www/trac/proj4j/conf/trac.ini:always_notify_owner = true
/var/www/trac/proj4j/conf/trac.ini:always_notify_reporter = true
/var/www/trac/proj4j/conf/trac.ini:always_notify_updater = true
/var/www/trac/proj4j/conf/trac.ini:repository_dir =
/var/www/svn/repos/metacrs/proj4j
/var/www/trac/proj4js/conf/trac.ini:always_notify_owner = true
/var/www/trac/proj4js/conf/trac.ini:always_notify_reporter = true
/var/www/trac/proj4js/conf/trac.ini:always_notify_updater = true
/var/www/trac/proj4js/conf/trac.ini:repository_dir =
/var/www/svn/repos/metacrs/proj4js
/var/www/trac/qgis/conf/trac.ini:always_notify_owner = true
/var/www/trac/qgis/conf/trac.ini:always_notify_reporter = true
/var/www/trac/qgis/conf/trac.ini:repository_dir = /var/www/svn/repos/qgis
/var/www/trac/tilecache/conf/trac.ini:always_notify_owner = true
/var/www/trac/tilecache/conf/trac.ini:always_notify_reporter = true
/var/www/trac/tilecache/conf/trac.ini:always_notify_updater = true
/var/www/trac/tilecache/conf/trac.ini:repository_dir =
/var/www/svn/repos/tilecache/
/var/www/trac/ubuntugis/conf/trac.ini:always_notify_owner = true
/var/www/trac/ubuntugis/conf/trac.ini:always_notify_reporter = true
/var/www/trac/ubuntugis/conf/trac.ini:always_notify_updater = true
/var/www/trac/ubuntugis/conf/trac.ini:repository_dir =
/var/www/svn/repos/ubuntugis
hmm, for some reason I don't receive notifications from that /osgeo/ repository (Sys Admin component). Bizarre.
Anyway, now you know if I don't respond to updates in my own ticket ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
-jeff
On Fri, Jun 19, 2015 at 3:14 PM, Jeff McKenna
Ah, I think you have to do this:
(sent recently to grass-dev)
On Mon, Jun 15, 2015 at 11:14 AM, Markus Neteler <neteler@osgeo.org> wrote:
FYI
recently, the OSGeo trac server got updated. Apparently the personal
email preferences didn't survive this update.
If you want to again receive email notification upon trac ticket
updates, you need to login and re-enter your name and email address
here:
https://trac.osgeo.org/grass/prefs
Preferences
--> Full name:
--> Email address:
"This information is used to associate your login name with your email
address and full name, which is used for email notification and RSS
feeds, for example."
Best,
PS: thanks to Moritz Lennert for identifying this issue.
HTH,
FYI
here:
Good thought, I had thought that too earlier before I sent this to SAC so I checked it and my FullName and Email Address were properly set already ![:frowning: :frowning:](/images/emoji/twitter/frowning.png?v=12)
So, that is why I sent the email to SAC.
-jeff
-jeff
I did just now press "Save Changes" in preferences (but I didn't change my email address)...hopefully that does the trick? ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
jeff
