Just some ideas to get us looking at options.
-Alex
-------- Original Message --------
Subject: Your Silicon Mechanics Quote: #172754
Date: Fri, 06 Nov 2009 14:03:36 -0800
From: Silicon Mechanics <quotes@siliconmechanics.com>
Reply-To: Silicon Mechanics <quotes@siliconmechanics.com>
Organization: Silicon Mechanics
To: tech@wildintellect.com
Hello,
A quote has just been created in your name at Silicon Mechanics. As a
courtesy, this automated message is being sent to you with the details
of that quote.
===========================> Billing Address <============================
===========================> Shipping Address <===========================
============================> Quote Details <=============================
Quote ID: 172754
Confirmation: 858253732
Description: OSGeo Example
Created: 11/06/2009
Expires: 12/06/2009
=================================> Notes <================================
===============================> Contents <===============================
# Qty Name Price Subtotal
1. 1 Rackform nServ A2121 "OSGeo Example" $4614.00 $4614.00
Details:
Shared Chassis: The following chassis resources are shared by both
compute nodes
External Optical Drive: No Item Selected
Power Supply: Shared, Removable 980W Power Supply with PFC - 92%
Maximum Efficiency
Rail Kit: 1U Sliding Rail Kit Included
Compute Node 1: The following choices apply to Compute Node 1 (Left
side when viewing chassis from the front)
CPU: 2 x Opteron 2374 HE (2.2GHz, Quad Core, SktF, 512KB/Core L2
Cache, 6MB L3 Cache) 55W 45nm
RAM: 32GB (8 x 4GB) DDR2-800 Registered ECC - Interleaved
NIC: Dual-Port nVidia MCP55V-Pro Gigabit Ethernet Controller
Management: No Item Selected
Low-Profile PCIe x16: No Item Selected
Hot-Swap Drive - 1: 500GB Seagate Barracuda ES.2 (3Gb/s, 7.2Krpm,
32MB Cache, NCQ) SATA
Hot-Swap Drive - 2: 500GB Seagate Barracuda ES.2 (3Gb/s, 7.2Krpm,
OS: CentOS 5 - 64-bit - Preload, No Media
Compute Node 2: The following choices apply to Compute Node 2
(Right side when viewing chassis from the front)
RAM: 2GB (2 x 1GB) DDR2-667 Registered ECC - Interleaved
OS: Ubuntu 8.04 LTS Server Edition - 64-bit - Preload, No Media
Warranty: Standard 3-Year Warranty
Configured Power: 585 W, 600 VA, 1996 BTU/h, 5.5 Amps (110V), 2.9
Amps (208V)
Tax (0%): Unavailable*
Total: $4614.00
* Our tax service is temporarily unavailable, and we are unable to
calculate your subtotal. To try to update your subtotal, click on "View
Cart" at the top of this screen. Please do not reload the page. If the
tax service remains unavailable, you may choose to a) complete your
order, and we will contact you with complete tax information, and you
will have the opportunity to either cancel or fulfill your order at that
time; b) call our Sales Department at 866.352.1173 for complete
information; or c) return later and try again.
============================> Instructions <==============================
When you wish to access or purchase this quote, just follow the link
below and add it to your shopping cart:
Web:
http://www.siliconmechanics.com/quotes/172754?confirmation=858253732
PDF:
http://www.siliconmechanics.com/quotes/172754.pdf?confirmation=858253732
Or, if you wish, you can use the quote lookup form located in the side
menu anywhere within http://www.siliconmechanics.com/
