I've put in a bid for another contract to cover December 7th 2020 - March
31st 2021.
So this will mostly come out of next year's budget I think since it crosses
years and my first invoice won't be until December 31st / Jan 1st.
. #2534 - Reformat OSMF Servers as an lxd container/vm hosts
. #2533 - Resetup Grasswiki
I plan to containerize other things left on OSGeo 6 but haven't done a firm
analysis of it of what is left
Additional Tasks: Will be assigned by SAC via ticketing system tagged with
milestone: System Contract 2020-III
. General SAC support - e.g. helping with DNS, website configuration,
general problems, specialty site setup
. Patch updates on servers as needed
Hi Regina, I'm fine with you taking a new contract for those tasks,
but please let's keep trac clean. At the moment the
"Sysadmin Contract 2020-I" milestone still has 8 open tickets, shall
they be moved to "Sysadmin Contract 2020-II" ? Also please edit the
milestone to specify who's in charge for that milestone. I've done so
for the "II" milestone.
--strk;
31st 2021.
Just to get things in order, I think we need to finish drafting our 2021 budget first, and submit that to the Board. I will follow up with Michael to get our spend report for 2020 also.
Alex
--strk;
31st 2021.
Now that we have the budget, let's revisit getting a new system contract
setup.
Question: should next steps on the wiki user migration be part of this?
Alex
Alex
--strk;
March
31st 2021.
crosses
\. \#2534 \- Reformat OSMF Servers as an lxd container/vm hosts
\. \#2533 \- Resetup Grasswiki
a firm
with
configuration,
> contract setup.
Yes please! Today I've struggled with bringing LDAP back up as all our
services refused any authentication..
YES !
--strk;
Sorry for delay in responding. I'll resubmit my OSGeo contract bid based on
new contract limits and extend the period of service on it. I'd like to keep
the beginning if that as is if that is okay as I did some stuff I had
planned to be on this contract but held off on the billing since the
contract was not in place.
I did a quick look at the wiki script hexmode left.
At a glance it looks like he also added some wiki optimization changes.
I've created a wiki-staging container (backup of last night's wiki container
backup) on osgeo4 and was going to attempt to upgrade that with his
scripts/instructions.
Strk -- if that works, maybe we can try a second time with ansible. I'm
still a bit lost with ansible though. Mostly just the terminology and stuff
- so if you want to start an ansible script and I can fill in the pieces,
that would be helpful.
On a separate topic - where do we stand with the 2 new OSM servers? Strk
have you made any action on that?
The term you're looking for is "mediawiki ansible role". Look that up.
I'm not sure it exists, but it *might* (often people do write these
"roles" and publish them somewhere).
The look at deploy-ssh-hops.yml, see how it succintly requests
to install the "ssh-server" role to the "ssh_hops" hosts, passing
specific variables to the role.
You could do something similar with a new deploy-wiki.yml, requesting
to install the "mediawiki" (or whatever is called) role to the
"wiki" hosts.
These "hosts" are defined in inventory/{prod,dev}/hosts so you would
add an host in the "wiki" group in those files for whatever target
you want to address (stage ? dev ?) to do your tests.
