Hi SAC,
by chance I discovered:
webextra: /dev/vda3 20G 19G 0 100% /
I suppose that the machine will crash soon.
Maybe it is a bad idea to put /osgeo into the / partition...
Hi SAC,
On Sat, Apr 7, 2012 at 11:52 AM, Markus Neteler <neteler@osgeo.org> wrote:
Hi SAC,
I have done some brute-force:
rm -f vmap0-access.log.30.gz vmap0-access.log.17.gz
vmap0-access.log.14.gz vmap0-access.log.13.gz vmap0-access.log.12.gz
vmap0-access.log.11.gz
Now 2GB are back.
Apache restarted, now also Munin is back.
Added two favico.ico files (using the OSGeo one) to avoid massive
clutter in the apache error log files.
Still more space is needed on that machine.
Sorry, I'm out of service for the rest of the day (family day now and
glider towing this afternoon), but will have a look at it on sunday, if
nobody beats me).
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
I've just issued a reboot on "webextra" to to get the services into a
clean state.
Wrt. VMap0 tile service on "wbextra", I've replicated most (of maybe
even all) of this on the "sphere.telascience.org" machine a couple of
weeks ago, thus if there's the desire to get it off "webextra", it
probably needs just a DNS change and some testing. I was unsure about
what the current plan is.
Martin.
BTW, isn't it wonderful how efficient modern filesystems are
webextra:/osgeo# pwd
/osgeo
webextra:/osgeo# du -hs .
28G .
webextra:/osgeo# df -h .
Filesystem Size Used Avail Use% Mounted on
/dev/vda3 20G 15G 4.5G 77% /
Martin.
Back to more reasonable stuff, I'm moving the entire "osgeo" directory
into the separate filesystem, I think that'll release some of the
pressure.
Martin.
I've moved the /mapdata/ into /osgeo/, map files in
"/osgeo/tiles/vmap0/" are modified accordingly - please test,
Martin.
.... btw. the (now) "/osgeo/mapdata/vmap.map" as well - I really
wonder, which place is referring to this particular file.
Martin.
clean state.Wrt. VMap0 tile service on "wbextra", I've replicated most (of maybe
what the current plan is.Cheers,
Martin.
I like the sounds of moving it to sphere.telascience
If you've tested it we should just move the dns for it.
I've just been doing forced logrotates on apache whenever it fills but happened to be offline this weekend.
Alex
I'm having just little knowledge about the various layers the WMS is
supposed to support, therefore it would be beneficial to know about
some prominent test cases. I'm aware of these file map files, are they
still maintained/needed ?
/osgeo/tiles/vmap0/openlayers.map
/osgeo/tiles/vmap0/vmap0.map
/osgeo/tiles/vmap0/vmap_wms_label.map
/osgeo/tiles/vmap0/vmap_wms.map
I hope I made this job easier by changing the weekly check interval
into a daily one in "/etc/logrotate.d/apache2"
Martin.
Hi SAC,
... while this one is solved (for now), I would like to bring the
script in this ticket to your attention:
http://trac.osgeo.org/osgeo/ticket/159
"We Need Low Disk notifier on osgeo1 and osgeo2"
--> Shell script to watch the disk space
I would suggest to add this on the critical machines and
simply post the warnings to this list (in the respective Mailman
settings we can enable single addresses to go through, the
email can be fetch from a dedicated account with fetchmail
to avoid a spam hole).
On 04/11/2012 02:12 PM, Markus Neteler wrote:
On Sat, Apr 7, 2012 at 11:52 AM, Markus Neteler<neteler@osgeo.org> wrote:
Hi SAC,
script in this ticket to your attention:http://trac.osgeo.org/osgeo/ticket/159
--> Shell script to watch the disk spaceI would suggest to add this on the critical machines and
to avoid a spam hole).Markus
From what I've read munin can do email notifications at certain events. If someone can figure out how to do that it would be fairly effective since munin updates every 5 minutes.
Alex
On Thu, Apr 12, 2012 at 5:52 AM, Alex Mandel <tech_dev@wildintellect.com> wrote:
Right - some random examples:
http://wiki.kartbuilding.net/index.php/Munin_Statistics#Email_Notifications_from_Munin
http://sysadminman.net/blog/2009/e-mail-alerts-from-munin-for-network-bandwidth-usage-253
http://blog.edseek.com/archives/2006/07/13/munin-alert-email-notification/
munin updates every 5 minutes.Right - some random examples:
http://blog.edseek.com/archives/2006/07/13/munin-alert-email-notification/Markus
Testing is under way. The one thing those pages don't discuss which I've
found is that you need Postfix or another tool for sending mail
configured correctly on the munin server.
Right now in my tests, it works but each warning is it's own email. I
see some instructions on how to pass the warnings to an outside script,
possibly for collating into a single email but I'm not sure how to
handle that.
http://munin-monitoring.org/wiki/HowToContact
I'll try to finish the setup this week, but the question I have is what
email address should we send to? There is a chance that it can generate
a lot of small emails when stuff goes wrong.
Alex
