The woodie server is not functional at the moment.
Debugging some I found the hosting LXD container
is missing a default route:
osgeo8:~$ lxc exec woodie-server -- ip route
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.29.0.0/16 dev br-c57c8b95f541 proto kernel scope link src 172.29.0.1
This makes it impossible for it to reach Gitea:
nc: connect to gitea.osgeo.org (140.211.15.57) port 443 (tcp) failed: Network is unreachable
-----Original Message-----
From: Sac [mailto:sac-bounces@lists.osgeo.org] On Behalf Of Sandro
Santilli
Sent: Saturday, July 15, 2023 3:21 AM
To: sac@lists.osgeo.org
Subject: [SAC] woodie server lost carrier, where is management
documentation ?
Debugging some I found the hosting LXD container is missing a default
route:
linkdown
172.29.0.1
failed:
I don't know why/how the network was corrupted and I was wondering how
woodie-server is be managed, to restart it, but did not find information
I tried logging into https://woodie.osgeo.org
and I was unable to presumably because of the network issue you mentioned.
After rebooting Woodie-server I was able to log in.
I do note that Woodie-server has only 25 GB left, so possibly maybe it ran
out of disk space at some point.
I'm going to prune the docker again and also allocate more space for
Woodie-server.
Regina
Sent: Saturday, July 15, 2023 9:32 PM
To: 'System Administration Committee Discussion/OSGeo'
<sac@lists.osgeo.org>
Subject: RE: [SAC] woodie server lost carrier, where is management
documentation ?
That's weird. It was working fine after I had upgraded it.
> Santilli
> documentation ?
route:
> linkdown
> 172.29.0.1
